How to Propagate Errors Across Models?
Error propagation between models is crucial when results from one model serve as inputs for another. In the discussed case, Model 1 produces a vector of Y values from a non-linear equation, but the associated errors for these Y values are not directly known. To estimate these errors, bootstrapping techniques are recommended for deriving error estimates for each Y element. Once the errors for Y are established, they can be propagated to Model 2 to calculate the corresponding Z values. Finally, RMSE for Model 2 can be computed using the propagated errors from Y.
nehajo88
Hi folks,
I have a rather simple question on error propagation - I have 2 sets of models, where the results from model are used as variables in the next model. I need to know how to carry forward errors from one to another.
Case -
Model 1: Y = a*exp(b*X) + c
The errors on X (which is a vector of about 100 samples) and Y (a vector of same size as X) are not know. From fitting the above non-linear model to the data and examining the residuals, I can calculate Mean Absolute Error, RMSE, etc. So, in the end I get a vector of Y values and a single error estimate from the model (e.g. RMSE).
Model 2: Z = s*(Y)^t + u
Where Y is the variable obtained from the results of Model 1. Applying Model 1 to a large number of new X values, I now have Y as a vector with > 10,000 elements. Each element in vector Y should have an associated error. My question is - what error should I give each element of vector Y? My next question is, once the error on each element of vector Y is known, how do I propagate this error to each element of vector Z? Finally, how do I calculate RMSE for Model 2?
All help will be much appreciated!
Thanks,
Yaal
If your process involves nonlinearity and complicated methods then your best bet will be to use some bootstrapping technique to get an estimate of the errors in Z.
http://en.wikipedia.org/wiki/Bootstrapping_(statistics )
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
