Radiation pattern of crt tv with small loop antenna
Using a small loop antenna with an old CRT TV reveals distinct frequency responses based on the antenna's orientation. Holding the antenna vertically produces a single spike at around 15 kHz, while a horizontal position generates multiple spikes, indicating different interactions with the TV's electromagnetic fields. The discussion highlights that the magnetic field is likely horizontal and the electric field vertical, as the loop antenna primarily responds to magnetic fields. Proper construction of sniffer probes is crucial for accurately sensing AC magnetic fields, and E-field shielding is recommended to eliminate unwanted capacitively-coupled signals. Overall, the findings emphasize the importance of antenna orientation and probe design in electromagnetic field detection.
mishima
I was playing with an old crt TV and a small loop antenna earlier and noticed that when I hold the antenna vertically in front of the TV I get one solid spike at around 15 kHz. When I hold the antenna horizontally I get a multitude of spikes that are not there when I turn off the TV.
This suggests to me that the field lines in the space inside my antenna are oriented in such a way that the magnetic field is horizontal, and the electric field is vertical. This is since the small loop antenna is affected most by magnetic fields, and they must be passing through the loop to induce current. Is that correct?
Assuming the B-field loop probe (often called "sniffer" probes) is made correctly, then yes, you are sensing the AC magnetic field that is caused by AC currents. Here is a good intro to sniffer probe construction and use:
http://www.compliance-club.com/archive/old_archive/030718.htm
If you are not building the probe correctly, then you are sensing a mix of AC B & E fields, which is generally less useful.
Nice, thank you for the very cool link. Currently my antenna is about 50 turns of wire on a wooden frame, those small sniffer probes would be very fun to build/use as well.
The single-turn, E-field shielded B-field probes as shown in the article generally require a preamp of 20-40dB before the signal is visible on a spectrum analyzer. You might be able to E-field shield your multi-turn coil if you follow the overall tips in the paper. The E-field shielding is necessary to keep capacitively-coupled signals out of your probe signal.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
