Normalizing Wave Functions Over Multiple Regions
SHISHKABOB
I need to normalize the following wave function in order to determine the value of the coefficients. This is from the basic finite square well potential.
\Psi(x) = Ae^{k_{1}x},for \ x < -a/2
\Psi(x) = Csin(k_{2}x),for \ -a/2 \leq x \leq a/2
\Psi(x) = De^{-k_{1}x}, for \ x > a/2
\int\left|\Psi(x)\right|^{2} dx = 1
Do I do an integral for each region, with the limits of integration being the boundaries of each region, and that integral normalized to 1 for each of those regions? Or do I add up those integrals with the same limits of integration and then set that equal to 1?
You use the fact that the wavefunction is continuous at each connecting point,
(-a/2), a/2, to write C and D in terms of A.
Then you integrate the piecewise-function squared over the whole interval to tell
you what A should be.
[also this might be a solution to the finite square well but it's not the most general solution, which
allows cos(kx) in the middle as well. <-- totally meant this to be punny
This. More explicitly:
$$\int_{-\infty}^{+\infty} {|\Psi|^2 dx} = 1 \\
\int_{-\infty}^{-a/2} {|\Psi_1|^2 dx}
+ \int_{-a/2}^{+a/2} {|\Psi_2|^2 dx}
+ \int_{+a/2}^{+\infty} {|\Psi_3|^2 dx} = 1$$
This is the same thing as if you were to integrate a single function over the entire range from -∞ to +∞, by splitting up that range into three pieces and doing those as separate integrals for whatever reason.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
