Ebers-Moll: Ic is nonconstant, but Vbe is approximately constant.
  • Thread starter Thread starter Mark9
    Constant Ic
The Ebers-Moll equation indicates that while Vbe is approximately constant around 0.6 volts, it does vary slightly with changes in current, impacting Ic significantly due to the exponential relationship. The discussion clarifies that small variations in Vbe can lead to large changes in Ic, especially in large signal analysis, where DC values are used to determine quiescent conditions. It is emphasized that while Vt is low (23.5mV), a higher Vbe (around 0.6V) is necessary in practice to ensure the transistor is fully conducting, as even small forward voltages can result in minimal current flow. The complexity of BJT behavior is highlighted, noting that even at lower Vbe values, there can still be a small reverse saturation current. Understanding these nuances is crucial for accurate transistor current source design.
Mark9
Hello all,
The Ebers-Moll equation as I understand it is: Ic = Is*exp((Vbe/Vt) -1). Question1: Assume fixed temperature; if Vbe is approximately 0.6 volts, as is typically used in transistor current source analysis, then how does Ic change at all? A core issue here is that I was under the impression that since Vbe is basically due to diode forward drop, that Vbe should be approximately constant. I'm looking to understand the NPN transistor as transconductance device(Vbe controls Ic), but the way I'm reading things, the equation just gives me a constant Ic(for fixed Temp). Question2: If the answer is that Vbe does indeed vary, then please clarify how this is possible. I thought that diodes maintained constant(approximately) forward voltage drop over a wide range of currents.
Thank you in advance to any takers!
Mark
Question 1: Vbe is approximately 0.5 - 0.7 volts depending on temperature and various other factors, but it does change. If you change the current through it, Vbe changes to accommodate that. Note the Ic is exponentially related to Ic, so only a small change in Vbe is needed to bring about a large change in Ic.
Also, don't confuse Large Signal analysis with Small Signal analysis. The large signal analysis would be to look at the DC value of Vbe to get the quiescent or DC value of Ic. Then you would super impose a small sine wave (for example) on Vbe which is translated into a sinusoidal variation in Ic. This is transconductance and its a small signal property.
Question 2: The answer is in your question! The diode only maintains "approximate" forward voltage drop, and a little variation in voltage can translate into a big variation in Ic because of the exponential relation.
Thank you analogdesign! If you don't mind, I would like to try to check my understanding by restating in different words something you've said, and then ask a quick follow up question. Please correct me if I'm mistaken. Then the reason why I can use a value in the range 0.5-0.7 as an estimate of Vbe in,say, designing a transistor current source, is because my driving base voltage(Vb relative to ground) will be orders of magnitude larger than Vbe. So the small differences(0.5,0.6,0.7 etc..) won't significantly impact any such calculations. BUT, when considering Ic, even small deviations count, so the ebers-moll exponential relationship is necessary.
FOLLOW UP QUESTION: Since(at room temp) Vt = 23.5mV, this means that(according to ebers-moll) Ic>0 whenever Vbe>0.0235. But I've read that to ensure that the emitter is conducting, (i.e., Ic >0) I must make Vbe>0.6. But the difference 0.6 - 0.0235 is quite large and NOT negligible from the perspective of the ebers-moll equation. So why the large discrepancy, and do I really need Vbe > 0.6? Is there some reason why it is necessary in practice to make Vbe so much bigger than Vt=23.5mV??
Hi Mark,
Almost, but not quite. 0.1 V is a big change. I was thinking like a sinewave on the order of mV riding on the 0.6 or 0.7. Large signal BJT calculations are almost trivial because just remember Ic about equals Ie and Ic = Beta*Ib.
FOLLOW UP:
The BJT is a very complex device from a physics standpoint. The transition from OFF to ON is not super sharp, so there *is* current flowing even when Vbe is small. Consider the "reverse saturation" current. It is the "Is" in the Ebers Moll eqn and it is very small. In fact it is typically less than picoamp (it depends on the details of the transistor's construction).
So, if VBE = 0.6 V, vt = 23 mV, and Is= 1pA then Ic = is*exp(vbe/vt - 1) = 78 mA *big*
Now if VBE = 0.1 (the BJT is "off") then Ic = 28 pA.
So the current is 9 order-of-magnitude smaller when VBE = 0.1. For most practical (but not all!) the device can be considered to be OFF.
Make more sense now?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
