Register to reply
Tio2 + water
by dana3kil
Tags: tio2, water
Share this thread:
dana3kil
#1
Nov19-13, 08:55 AM
P: 2
Hi every one .
I am trying to make nanocomposite and I need to solve nano Tio2 in water
many paper said that it will dissolve in water
but I could not .
I don not know what is the problem
Phys.Org News Partner Engineering news on Phys.org
Comfortable climate indoors with porous glass
Crash-testing rivets
Customized surface inspection
SteamKing
#2
Nov19-13, 10:21 AM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,344
TiO2 is insoluble in water. If 'many paper' say it is, they are either wrong or there is some procedure which is used and you are not picking up on it.
http://en.wikipedia.org/wiki/Titanium_dioxide
This article says nanotubes of TiO2 are prepared using either a strong NaOH solution or a dilute HF solution.
Alkim
#3
Nov19-13, 01:11 PM
P: 98
"Dissolve" and sometimes "solve" is often used as a synonym of disperse. So if you mean that you are unable to obtain a stable dispersion of your nanopowder, you should try adding a dispersant.
dana3kil
#4
Nov20-13, 01:32 PM
P: 2
Tio2 + water
Thank you
but in case of using a solvent how can I get rid of it . (water will evaporate )
and will dispersion give me homogeneous composite or I need to dissolve the material
Alkim
#5
Nov20-13, 02:48 PM
P: 98
As already said, TiO2 is insoluble in water in the sense of decomposing into free ions. However, with sufficiently small particles and appropriate dispersants you can obtain relatively stable suspensions. In the case of very small particles, i.e. nanosized ones the suspension is called colloidal solution. In order to obtain a homogeneous composite you need to obtain a homogeneous and stable suspension of your TiO2 and whatever other materials are to from the composite with the aid of a dispersant (also called defloculant sometimes). However, this approach is not very adequate for achieving homogeneity on the nanoscale since the nanoparticles easily flock together even in very well defloculated suspensions. For nanocomposites there are other methods for achieving high homogeneity such as sol-gel, polymerized complex, etc. I recommend you to go to the library and find a specialized book on ceramic materials or composites processing. Also check carefully if a synthesis procedure hasn't already been developed. There is a high probability there are publications describing it.
Register to reply
Related Discussions
TiO2 and ZnO nanoparticle Materials & Chemical Engineering 1
How to corrode TiO2 ? Chemistry 23
TiO2 + C + 2Cl = TiCl4 + CO2 Biology, Chemistry & Other Homework 0
Oxidation state of TiO2? Chemistry 3
TiO2 spin coating Chemistry 1
