Register to reply
Chair Conformations
by MathewsMD
Tags: chair, conformations
Share this thread:
MathewsMD
#1
Nov25-13, 09:16 PM
P: 295
In the attached file, it shows the two diagrams for a cyclohexane in its chair conformations. I was just wondering if there's any actual differences between these two structures if there were no substituents except H. Like is the top vertex that has an acute angle drawn in the image point up in the actual chair conformation or something like that? The reason I ask is because when you flip from one chair conformation to the other, you get the other image. I just don't understand how you know which image you start off and which one you end with. And by image, I mean the one of the two conformations drawn in the attachment if you did not understand.
I simply don't understand why we use two different base structures when you have essentially the same chair. I don't really see a difference in the actual cyclohexane 3D molecule when I make it using a model so any explanation would be great!
Thank you so much! :)
Phys.Org News Partner Chemistry news on Phys.org
Faster, cheaper tests for sickle cell disease
Simulations for better transparent oxide layers
Characterizing strontium ruthenate crystals for electrochemical applications
MathewsMD
#2
Nov25-13, 10:26 PM
P: 295
The only observation I've been able to make is that if the slope of the middle two lines of the body is pointing downwards (negative slope) then the bottom right corner carbon will have an axial substituent downwards. Also, if the slope is positive (the middle two lines are pointing upwards) then the bottom right corner substituents will be pointing up. Please correct me if this generalization is incorrect. Also, please point out any other similarities and differences between the two chair conformations if you can. :)
Borek
#3
Nov26-13, 03:21 AM
Admin
Borek's Avatar
P: 23,600
As long as there are no substituents these are identical. Rotate the molecule 180 deg.
MathewsMD
#4
Nov26-13, 12:06 PM
P: 295
Chair Conformations
Quote Quote by Borek View Post
So if a question asked, assuming C-1 is the bottom right carbon, which direction is the axial substituent pointing, is there a clear cut answer? Is it correct to assume it is downwards if the chair conformation shown has its middle two lines drawn downwards (the chair on the right)?
Yanick
#5
Nov26-13, 12:25 PM
P: 383
Placing artificial labels for the purposes of an exam or something would lead to a unique answer for sure. The positions which the substituents take at any carbon are classified as equatorial or axial, roughly speaking this corresponds to a substituent pointing up/down (axial) versus "out" (equatorial). When chairs flip, the axial positions become equatorial and vice versa.
The point however, is that physically the two conformations you have are equivalent. There is in fact no way to distinguish between the conformers because there is no way to distinguish between the substituents (they are all equivalent hydrogens). Either way you slice it, you'll have 6 equatorial and 6 axial hydrogens. If you exchanged one of the hydrogens for a deuterium or something else, you may be able to use some kind of spectroscopy or other to differentiate between the two conformations, provided the deuterium/substituent is not acidic/exchangeable with the solvent (which is the case here of course).
MathewsMD
#6
Nov26-13, 10:09 PM
P: 295
Quote Quote by Yanick View Post
Yes, I understand that when the substituents are the same, the conformations are actually indistinguishable. My question is regarding the purposes of an examination like you noted, where there are two drawing and each denotes a specific way to draw the substituent at that carbon, either up or down in that specific point of time. I was wondering if the the right structure (in the attachment) has an axial substituent pointing down on the bottom right carbon all the time and if the left chair conformation has an axial substituent pointing up on the bottom right carbon all the time. Just trying to find any confirmation on the two chair conformations. :)
Yanick
#7
Nov26-13, 10:54 PM
P: 383
I think what you said is correct, but I'm having a hard time understanding exactly what it is you mean. I find this kind of concept difficult to learn/explain in purely written word. Perhaps a picture will help.
See the picture here: http://en.m.wikipedia.org/wiki/Ring_flip
It codes the carbons and hydrogens and shows a ring flip. I think this should clarify any confusion.
Register to reply
Related Discussions
Cylohexanol stability of conformations Chemistry 1
I am Looking For a New Chair! General Discussion 2
The swivelling chair General Physics 2
Interchangeable chair General Engineering 10
Herculean Chair General Engineering 12
