Is It Better to Run or Walk in the Rain?
  • Thread starter Thread starter Simon Bridge
    Paper Rain
The discussion centers on a paper by Seongtaek Seo that explores whether running or walking in the rain results in less exposure to getting wet. The author uses geometric models to argue that running, at the right angle, minimizes rain exposure compared to walking, although this contradicts practical experiments. Critics highlight that real-life running involves dynamic movements that complicate the simplistic model used in the paper. The paper's conclusions are deemed questionable due to its lack of consideration for various real-world factors, such as splashing and body posture. Overall, the consensus suggests that the model fails to accurately represent the complexities of human movement in the rain.
Simon Bridge
I am looking for other opinions on the following that has come to my attention:
Seongtaek Seo (2013) Orthogonal Projection & Run or Walk in the Rain?
European Journal of Scientific Research
ISSN 1450-216X / 1450-202X Vol. 113 No 4 October, 2013, pp.560-570
Abstract:
In this paper, we will find the orthogonal projected length or area of some figures.
Especially it will show the simplest way to find the orthogonal projected area of ellipsoid. And
then we apply them to the problem “Run or walk in the rain?” We will consider that the objects
move in the rain in a given time as well as in a given distance. And we also take into account an
object which moves leaning its body. By a simple method in this paper, we can check the
conclusions the previous authors pointed out. Furthermore we can obtain the new formulas and
results. So I think, at least in theory, this paper will show the way to reach the final conclusion
about this problem.
Background see https://www.physicsforums.com/showthread.php?p=4603262.
I don't know what to think about the journal ... a pdf of the paper is attached to the linked thread.
Is that typical of the sort of thing they publish?
The author basically works out the volume that various primitives (rectangular prism, spheroid, cylinder) sweep out and multiplies this by the number density of raindrops ... the whole thing looks like it's done in the reference frame of the ground.
I think the conclusion is that running is better than walking, provided you run at the right angle to the rain. This appears to contradict simple experiments conducted using natural running vs walking in simulated in-Nature weather.
Author thinks there is application to astrophysics.
Real running is very different from models. Mythbusters took a crack at this once, and you can see from how they went about it that there are a lot of factors going into it.
But if we do take a model where a solid body simply moves through a field of rain drops (rain's frame of reference is far more convenient here) is there any surprise that moving faster gets the object less wet? A plane parallel to rainfall is going to seep out exactly the same area regardless. A plane orthogonal rain fall is going to pick up very little if it moves fast enough. An arbitrary body will trivially fall somewhere in between, with a slight advantage for a fast moving object.
But an actual running person is going to splash, bob, and go through a different sequence of poses than a walking person. Comparing such a simplistic model to an experiment with an actual person is absolutely pointless.
Yeah I saw the Mythbusters clip.
The model may be better applied to a planetoid moving through a debris field ... except: no gravity in the model.
I was surprised that it got published - then I find out that it is "pre-review". <sigh>
I believe the author would do better to remove the human and weather elements of the paper, and reduce the problem to a set of variables that can be accounted for and controlled. Or at least try to account for them to a higher degree, right now the paper fails at drawing his conclusion.
Has it occurred to anyone that if walking speed is half of running speed, one would be exposed to the rain for twice the time when walking? It's a fairly simple proposition regardless of the angle of the rainfall and the direction that the person might take.
There is already a thread on this paper. Please don't spawn additional threads.
https://www.physicsforums.com/showthread.php?p=4606353#post4606353
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
