Snow Load Calculator | Medeek Design
In summary, the conversation discussed the completion and relocation of the snow load calculator to a new page. The speaker also expressed their desire for an easy way to calculate ground snow loads, but mentioned that it is not currently possible. They also mentioned the addition of ground snow load maps for Utah, Montana, Oregon, and Vermont, as well as plans for creating a wind load calculator and an app for structural engineers. The speaker also shared their frustration with trying to implement a feature for solar panel companies and their success in creating an API for the ASCE ground snow load data. The conversation ended with the speaker announcing the upgrade of the snow load calculator with a PDF report output and plans to do the same for other calculators in the future.
medeek
46
Finally finished up the snow load calculator. Moved it to this page:
http://design.medeek.com/resources/snow/snow_calculator.pl
Give it a whirl and let me know what you think.
I wish there was an easy way to calculate the ground snow loads for a given location but unfortunately there is not.
I've slowly been adding the Table (b) jurisdictions to the Utah Snow Load Map. Note, these are exceptions to the standard snow load calculations and require special consideration or consulting with local building authority.
Oregon Snow Load map is up. This one, like the Montana Map, connects to the snow load database hosted by the SEAO. It also compares the retrieved value against the 20 psf snow load minimum as well as checks the modeled elevation against the actual site elevation and flags the user based on these checks.
The advantage to using this tool is that you don't need to know the lat. and long. off hand, just click on the map and it does the rest.
http://design.medeek.com/resources/snow/oregongroundsnowloads.html
Very nice!
Still plugging away at the ASCE Fig 7-1 Ground Snow Load Map here:
http://design.medeek.com/resources/snow/groundsnowloads.html
I've just secured permission from the ASCE to digitize and display this map with an associated licensing fee.
15 of 48 states done so far. It takes about an hour per state depending on how complex the snow loads are for that state.
I like your website; it is very polished, informative, and useful.
Do you plan on creating other calculators on your website?
1) Wind load (walls, corner zones, roofs, soffit zones).
2) Seismic load (multi-storey).
3) Shear wall design (hold-down anchors, panel nailing pattern and spacing).
Just completed the Ground Snow Load Map tonight.
Digitizing it, so that it was accurate, took far longer than I had planned on but once I was underway I wasn't about to stop.
Note how most of the western US requires case studies, hence many of these states have their own snow load maps and research to back them up.
I'm starting work on a wind load calculator that will complement the snow load calculator. After that I plan on creating an app for structural engineers to automate some of their analysis of residential structures.
Interestingly I had a company that manufacturers and installs solar panels contact me regarding the ASCE ground snow load map. They were wondering if there was a way so that their website could send an http request to the map with a latitude and longitude and have it kick back the snow load. Since the map is already in digital format you would not think this would be hard to do. So I got thinking about how I could build a program that given a certain lat and long would automatically click on the map and then fire back the elevation, snow load, etc...
The only problem is google maps implementation of the KML layer does not allow this transmittal of information. So I basically banged my head against the wall for almost 2 weeks trying to do the impossible. However, I was not ready to throw in the towel just yet. Since the KML data is just plain text, (coordinates) I thought there must be some way to analyze this data and determine if a given location is within a certain polygon and if it is then be able to assign that polygon description (ASCE snow load details) to a variable which is then delivered to the client. Turns out this is called the point in the polygon problem and it is well documented:
http://en.wikipedia.org/wiki/Point_in_polygon
So I was about to write an algorithm for ray casting which would have taken some time. Then I thought maybe someone else has done this before and sure enough I found a couple of good perl modules that handled this nicely and I narrowly avoided reinventing the wheel. Just a few lines of Perl later and I had managed to create a nice little API for the ASCE ground snow load data:
http://design.medeek.com/resources/medeekapi.html
Vermont Ground Snow Loads Map is now complete:
http://design.medeek.com/resources/snow/vermontgroundsnowloads.html
This zone map defines ground snow loads by township and city boundaries and is derived from the zone map on page 48 of the 2012 Vermont Fire & Building Safety Code.
Vermont is a small state so the KML for this map was relatively easy to create.
The snow load calculator has now been upgraded with a PDF report output, which is really nice for printing out hard copies.
I will probably do the same PDF report format for the wind, seismic and ground snow load maps as time allows.
Wish you had a snow load calculator for Wyoming??
Related to Snow Load Calculator | Medeek Design
1. What is a snow load calculator and how does it work?
A snow load calculator is a tool used to estimate the amount of weight that a roof or structure can handle from the weight of accumulated snow. It takes into account factors such as the shape and slope of the roof, as well as the location and expected snowfall in the area. The calculator uses mathematical equations and building codes to determine the maximum snow load capacity for a given structure.
2. How accurate are snow load calculators?
Snow load calculators are generally very accurate, as they use standardized equations and building codes to determine the snow load capacity. However, it is important to note that the actual snow load on a structure can vary depending on factors such as wind, temperature, and the type of snow. Therefore, it is always recommended to consult a structural engineer for a more precise calculation.
3. Can a snow load calculator be used for all types of roofs?
Snow load calculators can be used for a variety of roof types, including flat, gable, hip, and shed roofs. However, the calculations may vary slightly depending on the shape and slope of the roof. It is important to select the appropriate calculator for the specific roof type to ensure accurate results.
4. Is a snow load calculator necessary for all construction projects?
In areas with heavy snowfall, a snow load calculator is necessary for all construction projects to ensure the safety and stability of the structure. However, in areas with very little snow, a snow load calculator may not be necessary. It is always best to consult local building codes and regulations to determine if a snow load calculator is required for a specific project.
5. Are there any precautions to take when using a snow load calculator?
When using a snow load calculator, it is important to input accurate information about the roof and location to ensure accurate results. It is also recommended to consult a structural engineer for a more precise calculation. Additionally, it is important to regularly monitor and remove snow from the roof during heavy snowfall to prevent excessive snow load and potential structural damage.
  • General Engineering
9K
  • Mechanical Engineering
  • Mechanics
