Displacement reaction at solubulity limit. Does it stop or precipitate
In a single displacement reaction, if the displacing metal reaches its solubility limit before fully displacing the other metal, the reaction will continue until all available ions are reacted. In the example of lead displacing silver from silver nitrate, lead nitrate (Pb(NO3)2) can precipitate out once its solubility limit is reached. This means that while the displacement may slow down due to the saturation of the solution, the reaction does not stop entirely. Instead, excess lead nitrate will form as a precipitate, allowing the reaction to proceed until all available silver ions are displaced.
chemnoob
I'm wondering what happens in a single displacement reaction if the displacing metal (the one that's going into the solution) reaches it's solubility limit before the other metal in the solution is fully displaced.
Say for example you had a strong silver nitrate solution, and you placed enough solid lead in it to potentially displace all of the silver.
Pb + 2AgNO3 -> 2Ag + Pb(NO3)2
Since AgNO3 has approx four times more solubility than Pb(NO3)2, it is possible that the Pb(NO3)2 would reach it's solubility limit before all of the Ag is displaced. So when this happens does the displacement just stop (or drastically slow), or does the reaction continue, with the excess Pb(NO3)2 precipitating out?
Chemistry news on Phys.org
Reaction continues, precipitating lead nitrate.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
