Tensor Rank vs Type: Explained
ddesai
Tensors can be of type (n, m), denoting n covariant and m contravariant indicies. Rank is a concept that comes from matrix rank and is basically the number of "simple" terms it takes to write out a tensor. Sometimes, however, I recall seeing or hearing things like "the metric tensor is a rank 2 tensor" and also "the metric is a covariant 2-tensor or type 2 tensor" I assume the two concepts, that of "type" and "rank" are unrelated, but I want another perspective.
Also, in GR mostly we deal with tensor fields as well as tensors. At different points the rank (as in matrix rank) may be different. Is this true?
When books say "the metric tensor is a rank 2 tensor" they really mean it's a tensor field of type (0,2). In this context rank doesn't mean the dimension of the image of a linear operator acting on a vector space.
Rank = n+m. The tensors of a tensor field will always be of the same type. For example you wouldn't have field that was vector-valued at some points and scalar-valued at others.
@jcsd. That's clear. But you use the term "Rank" in a different way than for example, this paper: http://www.its.caltech.edu/~matilde/WeitzMa10Abstract.pdf. If we assume that rank is defined as it is in this paper, then can you still say it doesn't change as you move from point to point?
@Newton. So then folks mix the terminology.
I completely missed the analogy with matrix rank. I suppose the metric must always be rank 4 for this meaning of rank as it has a non-zero determinant. I also would guess that the rank of a tensor field could change from point to point, for example in any tensor field that was zero at some point, but wasn't a zero tensor field.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
