Understanding Mechanical Work: Ideal Gas and Fixed Pressure
The discussion centers on the definition of mechanical work in the context of ideal gases and fixed pressure. It clarifies that the expression dW = -PdV is misleading, as work and heat are energy in transit rather than state functions. Participants debate whether pressure can be considered fixed, with some arguing that W should equal PV, while others emphasize that work done by a gas is represented by dW = PdV, regardless of pressure constancy. The conversation highlights the importance of understanding how pressure and volume interact during processes, noting that work calculations depend on whether pressure or volume remains constant. Ultimately, the consensus is that work is not simply PV, especially when considering varying conditions in thermodynamic processes.
theory.beta
Hi all,
I was wondering if I am having a definition problem on mechanical work.
Since dW = -PdV (as I was told in class), is it correct to say the pressure is fixed with W = -PV, since dW = d(PV) = -VdP - PdV = -PdV suggests dP = 0?
Thanks
S.
No, it is not correct. dW is misleading notation. It suggests that dW is an infinitesimal change in some quantity, W, which the system possesses (a so-called 'function of state'). This is not the case. [For the same reason, dQ is also misleading notation, suggesting, wrongly, that some quantity, Q, is possessed by the system.] Work and heat are both energy IN TRANSIT, rather than residing in the system.
PV is a function of state (because P and V are both functions of state), but it is a mistake to regard dW as a differential of pV (or -PV).
Hi Philip,
Thank you for the reply. However, I still think P is fixed in general, leading W = PV. Let's look at an integral form of ideal gas law. In essence, we have dT = (PdV+VdP)/R; integrating this would give the ideal gas law. But the actual integrated solution as PV = nRT implies either dV or dP to be zero.
Another example would be the heat function in a system of fixed volume, where Q = W = E +PV (Landau textbook chapter 2, the W is a little confusing). He took the derivative of W into dP and dV separately.
Any thoughts? Thanks again.
S.
The differential work done by the gas on the surroundings is dW=PdV, not dW=-PdV. Even if the pressure isn't constant, the differential work is still PdV. This comes from dW=Fdl, where F is the force and dl is the differential displacement. Since F = PA, dW = PAdl. But Adl = dV. So dW = PdV. See my Blog on my PF personal page.
Chet
theory.beta said:
Hi Philip,
The integral of dT is not PV unless you start from absolute 0.
nRΔT = nR\int_A^B dT = \int_A^B (Pdv + VdP) = \int_A^B d(PV) = P(B)V(B)-P(A)V(A) = ΔPV
P could be constant in which case nRΔT = PΔV (i.e. ∫VdP = 0). Or V could be constant, in which case nRΔT = VΔP. Or P and V could both change. One cannot determine \int Pdv or \int VdP separately for a given process without knowing how P or V varies during the process. But from the ideal gas law, PV = nRT, we know that d(PV) = nRdT
AM
Two of the best known ideal cases (but good approximations to real changes) are isothermal and adiabatic expansions. P varies in both of these.
When P is constant, then W = P ΔV, not PV.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
