Calculating the requirements for magnetic levitation
The discussion focuses on calculating the required magnetic field strength of an electromagnet to successfully repel a permanent magnet and achieve levitation. The user proposes a formula that combines the permanent magnet's field strength and its weight to determine the necessary strength of the electromagnet. Participants emphasize the complexity of calculating forces between magnets and suggest checking units in the proposed equation. The conversation highlights the importance of understanding magnetic interactions and encourages further exploration of the topic. Overall, the user seeks guidance on their calculations and understanding of magnetic levitation principles.
downtownjapan
Hi everyone,
I am interested in using an electromagnet to repel a permanent magnet and lift it up, and I am thinking about how to go about calculating the required magnetic field strength of the electromagnet for this operation.
I have attached a rough conceptual drawing showing the electromagnet positioned underneath the permanent magnet, both enclosed in a tube to control the range of movement of the permanent magnet.
In the the section labelled Pic 1, the permanent magnet sits on top of the electromagnet, which is switched off. The permanent magnet is attracted to the ferrous core of the electromagnet.
In the section labelled Pic 2, the electromagnet is turned on. It repels the permanent magnet, lifting it up.
I am interested in calculating how strong the electromagnet needs to be in order to counter the attraction of the permanent magnet and repel it successfully.
Does anyone want to comment on the proposed following formula to calculate the required electromagnet field strength?
Required electromagnet field strength = permanent magnet's field strength + permanent magnet's weight
Am I on the right track with this reasoning?
Actually I studies very little science, and have never studied any physics at all. All of what little understanding I have comes from places like this forum - so any comments or suggestions would be much appreciated.
Thanks everyone!
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
