Impulse and maximum height of a particle
A particle experiences an upward impulse from a force described by F = -8t² + 8t over 1 second. The impulse calculated is 4/3, which leads to a final velocity of v = 3m/4, assuming the mass is m. To find the maximum height, the formula h_max = v²/(2g) is used, resulting in h_max = 9m²/(32g). The discussion emphasizes using the impulse-momentum theorem rather than taking the derivative of the force. The final height expression is presented in terms of the particle's mass and gravitational acceleration.
thaalescosta
A particle receives an impulse that lasts 1s, coming from a upwards vertical force. This force is given by the following equation: F = -8t²+8t.
What is the maximum height reached by the particle?
F = -8t²+8t
\int(-8t²+8t)dt = (-8t³ +12t²)/3
When t = 1s, I = 4/3. That's what I got as my impulse.
For the maximum height, I took the derivative of F and set it = 0, finding that t = 1/2
Now I don't know how to find the height with all the information I have.
thaalescosta said:
A particle receives an impulse that lasts 1s, coming from a upwards vertical force. This force is given by the following equation: F = -8t2+8t.
F = -8t²+8t
\int(-8t^2+8t)dt = (-8t^3 +12t^2)/3
Hello thaalescosta. Welcome to PF !
(Use ^2 for an eponent of 2 in Latex.)
There's no need to use the derivative of the force, F.
The change in momentum of the particle is equal to the impulse. (Impulse - Momentum Theorem)
Do you know the mass of the particle?
Got it :)
So I = ΔP = P_{f} - P_{i} = ∫Fdt, from i to f
My impulse turned out to be 4/3.
The mass of the particle wasn't given. I'm guessing that the answer will be in general terms.
If I = m.v, then v = 3m/4
And if the maximum height is
h_{max} = v²/2g
then
h_{max} = 9m²/32g
Does this make sense?
thaalescosta said:
Got it :)
h_{max} = v²/2g
then
h_{max} = 9m²/32g
Yes.
You probably should enclose the entire denominator in parentheses.
h_{max} = v^2/(2g)
h_{max} = 9m^2/(32g)
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
