How to Achieve a Clean, Perpendicular Cut on a Plastic Rod?
  • Thread starter Thread starter downtownjapan
    Cutting
To achieve a clean, perpendicular cut on a plastic rod, it's essential to select the appropriate plastic material based on the intended application. The cutting process requires careful consideration of the offset between tool edges, ideally around 10% of the material thickness, to minimize energy and ensure a clean shear. Insufficient edge separation can lead to increased energy requirements and a less clean cut. Rotating the material during cutting can help control the angle, and incorporating a relief angle of about 2° on the cutters enhances the cutting efficiency. Proper preparation and technique are crucial for achieving the desired cutting results.
downtownjapan
Hi everyone,
I have a plastic rod that is cut/snapped between two metal clamps. I want the break in the material to be at an angle perpendicular to the rod's surface. Can anyone tell me what factors effect this operation? How can I select the best material for the plastic rod?
Thanks in advance (sorry if the question is unclear - I have tried to explain the best I could :-)
Why are you doing this ?
Maybe a study of shear bolt applications would be more appropriate.
You should primarily select the plastic material based on your application.
The cutting of the material is then a secondary issue. When punching holes or shearing material, the minimum energy is required when the tool edges that initiate the shear are offset by about 10% of the material thickness. That will result in a diagonal shear at about 5.7°. If the cutting edges have insufficient separation then there will be significant additional energy needed to crush the middle of the material.
The exact offset needed for minimum energy depends on the material being cut. When the offset is correct, there will be a shear across the entire cut surface. If there is a polished part then the edge separation is not optimum.
Where the shear needs to be perpendicular to the material, it is necessary to rotate the material being cut to control the angle. There should also be a relief angle of about 2° on the side of the cutters.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
