Term for the path of the subsolar point
In summary, the line that passes through the center of the Sun and the center of the Earth is called the solar equator. Twice per year, this line runs through the center of the Earth and the center of the Sun. The positive direction for the x-axis runs from the center of the Earth to the center of the Sun on the vernal equinox. Right ascension measures the position of the star relative to the positive x-axis, and declination measures the North-South position of the star relative to the equator.
snoopies622
840
28
Imagine a straight line that contains both the center of the sun and the center of the earth. This line passes through a point on the surface of the Earth that is between those two points. As the Earth rotates, this point moves west, forming a kind of line on the surface of the earth.
What is this line called? I was south of it once while visiting Aruba and thought it was so neat to see the sun apparently move from right to left across the sky instead of the other way. Thanks!
Astronomy news on Phys.org
The line is (approximately) a line of latitiude. The approximation is due to the Earth's revolution around the sun. It varies over the year between the Tropic of Cancer (~ 23 deg. north, June 21) and the Tropic of Capricorn (~ 23 deg. south, Dec. 21).
If I'm not mistaken the " thermal equator" may be what your looking for, could be wrong though
edit just noticed this recent post I was off lol.
BobG said:
The ecliptic plane is the plane of the Earth's orbit around the Sun. The equatorial plane is the plane of the Earth's equator. The Earth's equator is tilted at an angle to the ecliptic plane. The intersection of those two planes forms a line. This line forms the x-axis of the geocentric equatorial plane.
This line also runs through the center of the Earth, which is the origin of the geocentric equatorial coordinate system. The only thing left to do with this line is decide which direction is positive and which direction is negative. Twice a year (vernal equinox & autumnal equinox), the line formed by the intersection of the ecliptic plane and equatorial plane runs through both the center of the Earth and the center of the Sun. The positive direction for the x-axis runs from the center of the Earth to the center of the Sun on the vernal equinox.
Right ascension measures the position of the star relative to the positive x-axis (the direction of the vernal equinox) around the equatorial plane. You use the right hand screw rule to figure out which direction is positive (positive would be counter-clockwise if viewed from the outside of the system).
And, yes, many astronomical books identify right ascension, which is an angle, by Hour Angle. There's approximately 15 degrees per hour (15.04 if you want to be a little more exact).
Declination measures the North-South position of the star relative to the equator. Positive angles are to the North. Negative angles are to the South.
As someone else mentioned, the long term position of the stars isn't stationary due to precession of the Earth's axis, which leads to a somewhat strange situation. If it doesn't happen to be the vernal equinox, you need a different method to find the positive direction of the x-axis. The solution is to look at the star (or a point in space relative to a few stars) that would be directly behind the Sun on the vernal equinox. This star (or point in space) is called the First Point of Aries. You'd think this point must lie in the constellation Aries, but, thanks to precession, the First Point of Aries actually lies in the constellation Pisces (it's too hard to go back and change books already printed so the term has never been changed even though the point has moved).
Someday soon (at least in astronomical terms) the First Point of Aries will enter the constellation Aquarius. And, at that time, there will be much singing.
https://www.physicsforums.com/showthread.php?t=740103
That point on the surface of the Earth is called the "sub-solar point". I don't think the line it traces out has a name.
You can see the Sun move right to left by just bending over backward and watching it that way (from the northern hemisphere). Not very convenient, however.
Related to Term for the path of the subsolar point
What is the "term for the path of the subsolar point"?
The term for the path of the subsolar point is known as the "Analemma". This term comes from the Greek word "analema" meaning "support" or "prop". It refers to the shape traced by the position of the subsolar point over the course of a year on a map or globe.
What causes the subsolar point to change its position?
The subsolar point changes its position due to the Earth's tilt on its axis and its orbit around the sun. This tilt and orbit cause the sun's direct rays to fall at different latitudes throughout the year, resulting in a change in the subsolar point's location.
How often does the subsolar point return to a specific location?
The subsolar point returns to a specific location once every year on the same day. This phenomenon is known as the "analemma loop". The subsolar point returns to the same location on the same day due to the Earth's consistent tilt and orbit around the sun.
What is the significance of the subsolar point?
The subsolar point has several significant implications. It is used to determine the time of day and the length of daylight at a specific location. It also affects the weather patterns and climate of a region. Additionally, the subsolar point is used in navigation and celestial calculations.
Can the subsolar point be observed in the sky?
Yes, the subsolar point can be observed in the sky. It appears as the point directly below the sun at solar noon. This point will change its location in the sky throughout the year, following the analemma shape. However, it is only visible in the sky during the equinoxes, when the sun is directly overhead at the equator.
  • Astronomy and Astrophysics
113K
