How to Determine Mass Flow Rate for Adiabatic Compression of Nitrogen?
  • Thread starter Thread starter Fluidman117
    Compressor Work
The discussion focuses on calculating the mass flow rate and work performed by a compressor during the adiabatic compression of nitrogen. The initial and final enthalpies are given, along with the volume flow rate and densities at low and high pressures. Participants clarify that the mass flow rate should be calculated using the density at the higher pressure, as this reflects the conditions after compression. The need to integrate power over time to determine work is also emphasized, with a suggestion to calculate the work done on compressing 1 kg of nitrogen. Understanding the correct density to use is crucial for accurate calculations in practical applications.
Fluidman117
Nitrogen was compressed from initial pressure of 101 kPa to a higher pressure. The respective enthalpies are: 54 kJ/kg and 350 kJ/kg. The compression process is adiabatic and ideal. The volume flow rate is 0.05 m^3/s. Density of Nitrogen before entering the compressor is 1.1 kg/m3 and at high pressure it is 35 kg/m3.
Calculate the work performed by the compressor?
W = m_dot * (h2-h1);
m_dot - mass flow rate in kg/s
h1 = 54 kJ/kg
h2 = 350 kJ/kg
m_dot = Q*rho
Q = 0.05 m^3/s
It is easy to plug in the numbers and calculate it, but I am a bit confused about the mass flow rate. When calculating the mass flow rate, do I have use the density at lower pressure or higher pressure and why?
##P=\dot{m}\Delta h## - That would be the power of the compressor, its units are [J/s]
To calculate work, you'll need to integrate the power over time. Probably they want you to calculate the work done on compressing 1 kg of nitrogen. That's where you'll need both densities, to estimate how long does the compressor take to raise the density of 1kg nitrogen. Once you have the time interval, then
##Work=\dot{m}\Delta h \Delta t##
h1 = 54 kJ/kg
h2 = 350 kJ/kg
m_dot = Q*rho
Q = 0.05 m^3/s
You've definitely done this calculation correctly. I think the volumetric flow rate corresponds to the exit of the compressor. If it was the inlet, the mass flow rate would only be 0.05 kg/sec (=3 kg/min) which sounds awfully low for any practical application. On the other hand, 105 kg/min is more like it.
Chet
