Manufacturing question for thermal expansion disagreement
In summary: Puckette give the following ranges of α:α=0.0005-0.3In summary, the range of α for structural steel is 0.0005-0.3.
adammclean1
Hello, my colleague and I are having a disagreement about the amount of thermal expansion in a particular part we are working on (manufacturing environment).
It is a piece of structural steel, which has a thermal expansion value of 12 (10^-6/K according to the chart at http://www.owlnet.rice.edu/~msci301/ThermalExpansion.pdf - please check out to confirm ) and we are wondering how much linear expansion would take place over a distance of 2.794 meters with every 1 degree (K/C) change in temperature. I will not bias the answers by posting what each of us think. Please help us solve this debate. Thanks!
I believe that 12 is the coefficient of thermal expansion on that chart, we are looking for linear expansion at every degree temp change.
Welcome to PF;
The figure given in the reference p11 for (structural) steel is for linear thermal expansion.
If the sheet starts out with length L, then is heated by ΔT, the change in length is given by:
##\Delta L = \alpha L \Delta T## (1)
A 1m sheet will increase it's length by 12 microns per degC
A 2m sheet will increase by 24 microns per degC
If 2.794m is the initial length of the sheet, then sgb27 has it right :)
But I think you are after something else...
After heating by ##\Delta T##, the new length is (from equ 1) given by:
(2) ##L=L_0(1+\alpha\Delta T)##
... let's compare this with the case we increment by 1deg at a time:
If you start at ##L_0## at 20degC then ##L_1=L_0(1+\alpha)## at 21degC
the next degree takes you to ##L_2=L_1(1+\alpha)=L_0(1+\alpha)^2## at 22degC and so on...
...so a whole N degrees heating to 20+N degC gives final length
(3) ##L_N=L_0(1+\alpha)^N \simeq L_0(1+N\alpha)##... provided ##\alpha<<1##.
i.e. eqn(2) is actually an approximation.
I suspect this is the heart of the dispute.
Simon is of course correct, however I suspect that a larger source of error when using eqn(2) with large temperature changes is that the coefficient of expansion is not constant over temperature.
Indeed - and the reference cited says:
, (CTE) Approximate Ranges at Room Temperature to 100 °C (212 °F),
-- Table 2.1 p11​
... which is why I was careful that my heating example started at 20degC ;)
If OP is thinking of ΔL=2.794m, I don't really know what is intended by that figure, then the sheet must start out over a km long for the number to be valid.
For 100 degrees temp change:
A 1m sheet of that steel would increase it's length by 1.2007mm, predicted by equ(3).
That would be a 1.2000mm increase by equ(1) - a difference of 0.7 microns in the predictions.
... about the wavelength of dark red light.
If you got anything different, then it is because the coefficient is only valid for the particular kind of steel and under specific conditions.
Need to hear from OP now :)
Actually, the more technically correct and precise definition of the coefficient of thermal expansion is:
[tex]α=\frac{d\ln L}{dT}[/tex]
So, [tex]\frac{L}{L_0}=e^{αΔT}[/tex]
or, if the coefficient varies with temperature:
[tex]\frac{L}{L_0}=\exp \left(\int_{T_0}^T{α(T')dT'}\right)[/tex]
Chet
1. What is thermal expansion and why is it important in manufacturing?
Thermal expansion is the tendency of materials to expand or contract when exposed to changes in temperature. In manufacturing, this is important to consider because it can affect the dimensions and tolerances of a product, leading to issues with fit and function.
2. How does thermal expansion differ between materials?
The degree of thermal expansion can vary greatly between different materials, with some expanding more than others. This is due to the atomic structure and bonding of the material, as well as the temperature range in which it is being used.
3. What are some common causes of thermal expansion disagreement in manufacturing?
One common cause of thermal expansion disagreement in manufacturing is using materials with different coefficients of thermal expansion, which can lead to dimensional differences. Other factors include improper temperature control during production and inadequate allowance for thermal expansion in design.
4. How can thermal expansion disagreement be prevented or minimized in manufacturing?
To prevent or minimize thermal expansion disagreement in manufacturing, it is important to use materials with similar coefficients of thermal expansion, maintain proper temperature control during production, and incorporate allowances for thermal expansion in the design phase.
5. What are some methods for measuring and compensating for thermal expansion in manufacturing?
There are several methods for measuring and compensating for thermal expansion in manufacturing. These include using specialized equipment such as thermal expansion gauges, conducting thermal analysis during the design phase, and implementing compensation techniques such as pre-stressing or incorporating expansion joints in the design.
  • Thermodynamics
  • Mechanical Engineering
