| Thread Closed |
Baricentre (barycenter) - does it 'wobble'? |
Share Thread |
| May6-05, 08:30 AM | #1 |
In another thread, in General Astronomy & Cosmology, the baricentre (or barycenter, for those in the US) was mentioned.
Here are the relevant statements: Does the baricentre 'wobble'? If so, how and why? If not, why not? |
| May6-05, 09:34 AM | #2 |
I also note now for the first time, that the line of importance (assuming Earth based observations of black holes gravitational lens effects) is between the star with changing light curve and the Earth, not the baricenter, not that this fine distinction makes any significance difference, which is why I did not mention it in original thread, but this is a "clean start" so that fact should at least be noted. |
| May6-05, 10:42 AM | #3 |
Recognitions:
AM |
| May6-05, 03:51 PM | #4 |
Baricentre (barycenter) - does it 'wobble'?(1) Do you agree that to first approximation, in this three object solar system, the baricenter is always in the ecliptic of Jupiter? (2)Exactly so, to all orders, when Pluto is also in Jupiter's ecliptic, but when Pluto is climbing higher and higher above Jupiter's ecliptic the next order approximation shows the baricenter is moving farther and farther above the ecliptic of Jupiter also? (Motion is relative so it could well be, as you suggest, that the baricenter is fixed and Jupiter's ecliptic is moving "down.") If you agree to these two (and I think you will) and continue to think that the baricenter is not moving, then it must be that the ecliptic of Jupiter is dropping farther and farther below the baricenter as Pluto climbs higher and higher above it. What I don't understand is why, relative to a fixed baricenter, the ecliptic of Jupiter should move below the fixed baricenter despite the gravitational attraction of Pluto, weak as it may be, tending to lift the ecliptic plane of Jupiter. I admit to having a strong inclination to agree that the baricenter is fixed, but am confused when I try to understand this three object solar system. I also want to note that in my original post I did mention exactly your "time dependent force being applied to the solar system as a whole" by citing a passing star. (or black hole - see new thread Could a local black hole exists undetected?) |
| May6-05, 11:22 PM | #5 |
Recognitions:
AM |
| May7-05, 04:24 AM | #6 |
I think this discussion has skipped over the most basic question in all considerations of motion; "moving relative to what?".
The Berry Center would indeed have the appearence of motion when viewed by any of the players in Billy T's theoretical model (the Sun, Jupiter, and Pluto). It is only to an outside observer, independant of Solar System dynamics, that it would be seen as constant, correct? |
| Thread Closed |
Similar discussions for: Baricentre (barycenter) - does it 'wobble'?
| Relativistic wobble? | Special & General Relativity | 9 | ||
| Wobble Hypothesis | Biology, Chemistry & Other Homework | 4 | ||
| football wobble | Classical Physics | 25 | ||
| G.warming: something to wobble about | General Physics | 10 | ||
| Asrophysics Orbit of Sun Barycenter | General Physics | 2 | ||
