Register to reply
Neutral axis-Biaxial bending
by mohamadh95
Tags: axisbiaxial, bending, neutral
Share this thread:
mohamadh95
#1
Apr4-14, 06:13 AM
P: 38
How can the neutral axis of a concrete column under biaxial bending be determined. I mean if the load P is given along with the eccentricities ex and ey, how could the N.A. location and orientation be computed?
Thank you.
Phys.Org News Partner Engineering news on Phys.org
Hoverbike drone project for air transport takes off
Student develops filter for clean water around the world
Developing the next evolution in underwater communication
paisiello2
#2
Apr4-14, 11:27 AM
P: 558
Since concrete and steel are both non-linear materials the only accurate way to do it is numerically using trial and error.
mohamadh95
#3
Apr4-14, 11:49 AM
P: 38
Well I'm willing to make a program using Mathematica or a spreadsheet in excel in order to create the interaction curve of a column,so trial and error is no problem. Can you explain how shall I do it? Should I assume an initial N.A and then do the computations, and after that check if the computation check with the N.A assumed position?
paisiello2
#4
Apr4-14, 01:15 PM
P: 558
That's pretty much it. Generally you have the vertical value of c and the rotation angle θ to locate it.
Now if you are doing an interaction curve that is a little different because now you are finding capacities which I think will turn out to be a little easier to do. A good reference is Collins & Mitchell's "Prestressed Concrete Structures".
mohamadh95
#5
Apr4-14, 02:36 PM
P: 38
Thank you for your help.
Register to reply
Related Discussions
Calculate the angle of the neutral axis from the x-axis Engineering, Comp Sci, & Technology Homework 24
Non-standard Beam Bending Question - Parallel to Neutral Axis General Engineering 3
Beam bending-neutral axis General Physics 4
Stresses and neutral axis Engineering, Comp Sci, & Technology Homework 3
Neutral Axis - Does it move? Mechanical Engineering 5
