Why is the universe considered as cold?
In summary, the universe is often considered a cold place due to its average temperature of 3 degrees Kelvin. However, stars are able to form due to the uneven distribution of matter and gravitational forces. The high temperature of stars and low temperature of interstellar space can be compared to two bonfires not melting snow in the Midwest. The speed of light traveling through space is not affected by temperature, but rather by obstacles such as black holes, planets, and interstellar gas. However, these objects are not common enough to significantly impact the overall movement of light, as the universe is largely made up of empty space.
ninja
Why do many claim the universe as a cold place? If it is the natural phenomena then how does formation of stars take place?
Astronomy news on Phys.org
Although the average temperature is cold (~ 3 deg. K), stars get formed because the distribution of matter is far from uniform. If sufficient matter clumps together under gravity, the clump will heat up and, if large enough, become a star.
http://en.wikipedia.org/wiki/Star_formation
The relative distance between stars is enormous. The high temperature of stars and low temperature of interstellar space is about as surprising as a bonfire in Maine and another in California failing to melt snow in the Midwest.
Thanks for the reply. I would rather like to take the discussion a further ahead - whether light speed traveling through space gets affected by prevailing temperatures or is it always uniform. Also, what apart from black holes could obstruct the light traveling through space.
The important aspect your missing is the sheer volume and overall energy density. If the volume of the universe increases, then the density of photons also increase. This will increase the pressure influence and temperature of the photons. In the case of stars which is far more dense than the surrounding space you have far higher temperatures. Google the gas laws as well as ideal gas laws (cosmology) for more details.
Uh ... anything that gets in its way? The Earth, for example. Other stars, other planets, interstellar gas. Now those things are so sparse that they don't stop much of it, but taken all together they stop way more than black holes do.
Objects, like black holes, planets and stars, are too uncommon to be a factor. The universe is more than 99.9% empty space.
Related to Why is the universe considered as cold?
1. Why is the universe considered as cold?
The universe is considered as cold because the average temperature of space is only about 2.7 Kelvin, or -270.45 degrees Celsius. This is due to the expansion of the universe, which causes the temperature to decrease over time.
2. How does the temperature of the universe compare to Earth's temperature?
Earth's average temperature is significantly higher than the average temperature of the universe. The average temperature on Earth is around 15 degrees Celsius, while the universe's average temperature is close to absolute zero, making it much colder.
3. What causes the universe to be cold?
The universe is cold due to the leftover radiation from the Big Bang, known as the cosmic microwave background (CMB). As the universe expands, this radiation is stretched out and becomes cooler over time.
4. Is the entire universe cold?
While the average temperature of the universe is very cold, there are still areas within the universe that are much hotter, such as stars and galaxies. However, these hot areas make up a small fraction of the overall universe.
5. Will the universe always be cold?
It is believed that the universe will continue to expand and cool down over time, eventually reaching a state of maximum entropy where the temperature will be equal everywhere. This is known as the "heat death" of the universe, where all energy is evenly distributed and no work can be done.
  • Astronomy and Astrophysics
