Force between two current-carrying loops
  • Thread starter Thread starter fogvajarash
    Force Loops
To calculate the magnetic force between two parallel, coaxial loops carrying currents in opposite directions, one can adapt the formula for the force between parallel wires. The magnetic field produced by one loop affects the other, and the force can be derived by considering the magnetic moment of the second loop and its potential energy at the distance separating them. The principle of virtual work can be applied, relating force to the change in potential energy as the distance between the loops varies. This approach, while advanced for introductory courses, remains manageable without complex mathematical tools. Understanding the interaction between the loops' magnetic fields is crucial for solving the problem effectively.
fogvajarash
Consider two circular, parallel, coaxial loops which are almost in contact. They are separated by 1.20mm, have 13.6cm as radius each. Both loops carry a current of I = 127A but in opposite directions. Find the magnetic force that the top loop exerts on the bottom loop.
I tried to "readapt" the force between two parallel wires, to be able to use it for two loops, in which we would have F = BIl = 2\pi BIr. Then, I used the formula for the field that a loop exerts on its axis, but now I'm doubting if this is true as actually this field is not felt by the other current loop. Now I am stuck on which way to calculate the force that one loop exerts on the other. I was thinking of finding the force exerted on one small piece of the circle dr and then try to integrate in order to find the total force.
Thank you for your time and patience.
Remember magnetic moment? Think of coil 1 as producing a B field along its axis, which you can easily compute. Then, think of coil 2 as having a magnetic moment, and then associate a potential energy U of that moment at the distance between the coils. So U = U(x) where x is the distance between the coils.
Then, appeal to the principle of virtual work which says that force x Δ(distance) = Δ(potential energy).
This problem is a bit advanced for an introductory course but not at all unmanageable (no elliptic integrals, legendre polynomials, etc.).
