What is the Definition and Nature of Baryon Resonances?
  • Thread starter rwooduk
  • Tags
    Baryon
In summary, a resonance is a short-living particle that appears as a peak in the scattering amplitude with a characteristic phase change.
rwooduk
762
59
i've looked online and the closest I've found to a definition is this:
A cross section anomaly indicating the existence of an unstable baryon.
what does this mean? i understand that an unstable baryon will decay into proton / neutron and a pion via the strong force. but what actually is this resonance? is it a resonance in the traditional sense? is it referring to the excited state of the baryon? does it have modes of vibration?
if someone could shed a little light on this it would be appreciated as there appears to be very little information on the internet that explains what a baryon resonance actually is or to what property the term 'resonance' actually refers.
A resonance is, in general, a very short living particle. In particular, for such particles it's pretty hard to define an actual value of their mass and this is basically a consequence of the uncertainty principle. If the particle is very short living then:
\Delta t\Delta E\sim\hbar\Rightarrow \Delta E\sim\frac{\hbar}{\Delta t},
and the spread on its energy (rest mass) is very large.
This particles are called resonances since they are so short living that they basically only appear as virtual states. Consider for example the scattering between two particles, say A and B: [itex]A+B\to A+B[/itex]. In QFT the cross section (i.e. more or less the probability) for this scattering to occur is the sum of all the possible Feynman diagrams that give you the same final state.
Now, if the energy of the two particles is reasonably close to the mass of this unstable particle, say X, you have one addition channel for your scattering: [itex]A+B\to X\to A+B[/itex]. Of course this is possible only if the quantum numbers are the right ones.
Then it turns out that right near the mass of this particle the scattering cross section as a function of the energy drastically increases (basically because of the presence of one additional channel) showing the typical resonant behavior.
Likes 1 person
I guess the name resonance came in use because of how they appear in experiments...
They appear as peaks of the cross section with respect to energy...
There's also a more satisfying explanation, in case you are familiar with classical resonances... For example if you check the wikipedia for resonances (http://en.wikipedia.org/wiki/Resonance) and take a look at the "intensity of oscillations I" formula, you will see a familiar formula (Breit Wigner cross section which describes resonances).
If you also read below the formula, it says that "The intensity is defined as the square of the amplitude of the oscillations"
And how is the differential cross section given? It's the square of the scattering amplitude...
You don't have any mechanical oscillation though... since the amplitudes of oscillations represent some mechanical motion, but the scattering amplitudes come from the interaction of the wavefunction with a local potential...
[itex] \psi_{scatt}= e^{ikx} + \frac{e^{ikr}}{r}f(k,k')[/itex]
http://en.wikipedia.org/wiki/Scattering_amplitude
Likes 1 person
Excellent replies as always! Thanks!
It's not just the peak in the scattering amplitude that matters. Even more important is its phase.
Here's a recent paper from the LCHb collaboration concerning their observations of a meson state, the Z1-(4430). To address the essential question "is it a peak, or really a particle" they say,
... the Z1- is represented by a Breit-Wigner amplitude where the magnitude and phase vary with m2 according to an approximately circular trajectory in the (Re A, I am A) plane (Argand diagram)... The resulting diagram is consistent with a rapid change of the phase when its magnitude reaches the maximum, a behavior characteristic of a resonance.
@Bill K
what else could a peak be but a particle? I'm asking because as far as I know:
peaks denote bound states... or semibound... depending on their branches...
Bound states appear in general as resonances...
Resonances are so short-living that you often see interference effects - and then you are sensitive to the phases. For long-living intermediate particles, interference effects (in the decays via those particles) are negligible.
This question has been extensively discussed in the context of the Z(4430) state, which thanks to the latest LCHb work now appears to be a genuine tetraquark, but several other proposals had previously been entertained.
One possibility was a weakly bound "molecular" combination of two mesons.
Another was a threshold effect, since its mass lies so close to the DD* threshold. See this paper, which says,
The Z(4430) can be fitted as a resonance but also can be fitted successfully by a cusp with no nearby resonant pole.
Likes 1 person
Related to What is the Definition and Nature of Baryon Resonances?
1. What are Baryon Resonances?
Baryon Resonances are subatomic particles that are made up of three quarks, which are the building blocks of protons and neutrons. They are unstable and can decay into other particles.
2. How are Baryon Resonances different from regular baryons?
Baryon Resonances have higher energy levels than regular baryons and are therefore more unstable. They also have shorter lifetimes and are more likely to decay into other particles.
3. What is the significance of Baryon Resonances in particle physics?
Baryon Resonances provide important information about the strong nuclear force, which is one of the four fundamental forces of nature. They also help scientists understand the structure of protons and neutrons.
4. How are Baryon Resonances studied?
Baryon Resonances are studied using particle accelerators, which can create high-energy collisions that produce these particles. Scientists also use detectors to observe the decay products of Baryon Resonances.
5. Can Baryon Resonances be used for practical applications?
Baryon Resonances have potential applications in medical imaging and cancer treatment, as well as in nuclear energy research. However, more research is needed to fully understand and harness their properties.
  • Beyond the Standard Models
  • Quantum Physics
