Galilean transformation problem (Speed)
A girl riding a bicycle passes a friend at a bus stop, and 60 seconds later, the friend catches a bus, with a distance of 126 meters between the events in the cyclist's frame. The calculation for the bicycle's speed yields a negative value of -2.1 m/s, which raises questions about its significance since speed is a scalar. The negative result indicates the direction of motion relative to the reference frame, where the cyclist perceives the ground moving backward. In the cyclist's frame, the events occur at 0 and -126 m, confirming that the distance is measured from the cyclist's perspective. Understanding the reference frames is crucial for interpreting the results correctly.
Ace.
A girl is riding a bicycle along a straight road at constant speed, and passes a friend standing at a bus stop (event #1). At a time of 60 s later the friend catches a bus (event #2)
If the distance separating the events is 126 m in the frame of the girl on the bicycle, what is the bicycle's speed?
u = u' + v
u = u' + v
can be written as:
Δx/t = Δx'/t + v
v = Δx/t - Δx'/t
v = 0m/60s - 126m /60s
v = -126 m/ 60s
v = -2.1 m/s
Just wondering if the negative holds any significance? I know we're talking about speed which is scalar but how come the calculation gives a negative?
u = u' + v
u = u' + v
can be written as:
Δx/t = Δx'/t + v
v = Δx/t - Δx'/t
v = -126 m/ 60s
v = -2.1 m/s
It should be +2.1 m/s. This is because the Δx' represents the displacement of the second event minus the displacement of the first. So v = 0/60 - (-126/60).
You are using the cyclist's reference frame with the origin at the cyclist to determine u' and the bus stop person's (bsp) reference frame with the bsp at the origin to determine u. There are two events: 1. the origins coincide and 2. the bsp enters the bus.
In the cyclist's frame these events occur at 0 and -126 m. using the direction of v as the +x direction. So Δx' = -126m. In the bsp's frame, they both occur at the origin.
AM
Likes Juwonjay
Why wouldn't it be +126 m if she is moving forward?
To the cyclist, the ground is moving backwards.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
