Miniature Bridge Design Ideas: Simple or Complex?
  • Thread starter Thread starter dabomb14
    Bridge Design
The discussion revolves around designing a bridge using play-dough, straws, and rubber bands within a 30-minute timeframe. The leader is considering whether to opt for a simple design, like a king or queen post, or a more complex structure, such as a solid ribbed arch or through truss. Key considerations include the trade-offs between design complexity, time constraints, and material limitations. Participants emphasize the importance of using straws effectively, noting that tension is easier to maintain than compression. Ultimately, the focus is on balancing design ambition with practical execution to ensure the bridge is completed successfully.
dabomb14
So I am the leader of a small group who has to build a bridge in 30 minutes on the last day of school. The only materials we can use are play-dough, straws, and rubber bands and it has to stretch 30 cm between two tables. Though I was looking for some ideas of a bridge design to use. Should I go with something simple like a king or queen post or something more complicated like a solid ribbed arch or a through truss? Any ideas or suggestions would be appreciated.
Welcome to the PF.
Can you say more about your own ideas for design options? What are the tradeoffs?
After thinking about the time it would take to do something very detailed, I was thinking about doing a king's post design. The main tradeoff would be time and material. If it is not completed in time or we a end up short a little of materials to finish, then obviously an unfinished bridge is going to fail.
How long are your straws?
Using them in compression is problematic, tension is easier to maintain.
I assume basic straw length. We get 50 straws and 300 rubber bands.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
