Can information truly be teleported using quantum entanglement?
Thinkor
I have seen numerous articles referencing the teleportation of information over a distance of 3 meters using quantum entanglement.
I don't believe it. That would contradict special relativity, would it not? You could, for example, decide which of two observers moving relatively to one another has the faster clock and which has the slower clock. One observer could encode the clock time into qubits and transmit them to the other. There would be no disagreement because quantum entanglement implies instantaneous correlation of states.
I think they are only querying the state of a particle. Of course, they then know that same state will be realized instantaneously at the other end, but that does not permit the transmission of information, yet the "leader" of the project, Professor Hanson of Delft University, is quoted as saying that "in principle it should be possible to teleport ourselves from one place to another". That would necessarily involve the transformation of the information within a person's brain.
No. To transmit information, those teleportation mechanisms always have to send classical information as well - and that is not faster than the speed of light.
In some (not all) interpretations of quantum mechanics, a part of the teleportation happens without delay (but even then you cannot tell in which frame it would happen without delay - every frame can share this view), but you cannot use this part alone for data transfer, for example.
Right, and it would need a massive classical data transfer.
I have two problems with your answer. First, directly from hansonlab.tudelft.nl/teleportation
Teleporting people through space, as is done in Star Trek, is impossible by the laws of physics. Teleporting information is another matter, however, thanks to the extraordinary world of quantum mechanics. Researchers at TU Delft’s Kavli Institute of Nanoscience have succeeded in deterministically transferring the information contained in a quantum bit – the quantum analogue of a classical bit – to a different quantum bit 3 metres away, without the information having traveled through the intervening space: teleportation. The results are published online in Science, on Thursday 29 May.
Second, there is a direct quote http://www.telegraph.co.uk/science/science-news/10863929/Beam-me-up-Scotty-teleportation-could-become-reality.html from Hanson claiming secure communication.
''One application nearest to a real life application is secure communication.
''What you're doing is using entanglement as your communication channel.
''The information is teleported to the other side, and there's no way anyone can intercept that information.
''In principle it's 100 per cent secure.''
If the information is really being teleported and there's no way to intercept it, then a transmission through the EM field is not taking place. If it is also being transmitted through the EM field, then there is no 100% security.
http://computerstories.net/dutch-scientists-teleport-data-for-the-first-time-ever/ is how they claim to do it.
Hanson and his colleagues had achieved weaving electrons or quantum bits in the passed, but for the very first time now also succeeded in successfully sending information using this phenomenon.
The scientists succeeded in placing an electron in a predetermined state of spin. They were than able to read or analyze this ‘spin’ three meters further by analyzing the other woven twin-particle or quantum bit.
I find this almost impossible to believe, especially because there is no claim of this being an exception to the principle of relativity, here or in any of the articles I have read.
You might want to read the wikipedia article on quantum teleportation: http://en.wikipedia.org/wiki/Quantum_teleportation
Mfb's answer is correct, and you are reading more into your material than is there.
The popular articles are wrong. Information is not being teleported. The same random bit is being created simultaneously in two places. That is a useful thing to be able to do, but it ("quantum information") is not "information". It is just more sloppy physics terminology.
Some of them are wrong, but the wikipedia page gives a good overview and has references to actual scientific articles.
I guess you are talking about entanglement here, which you have to do prepare between some states before you can teleport things. But "the same random bit" is misleading, as this looks like a purely classical description. The bits are more than "just the same".
Note that you cannot use "The same random bit is being created simultaneously in two places." to transmit any message. You know "hey, the other one sees the same bit", but you cannot fix this to a specific value. You can use it as secure one-time pad together with a classical channel.
Let's send a message in that way:
succeeded in deterministically transferring the information contained in a quantum bit [...] without the information having traveled through the intervening space
Yes, by performing quantum operations with the object to teleport and one entangled particle (in some interpretations of QM those involve instantaneous changes of the entangled partner).
You cannot use this to send a message. Just with this, for every bit sent, the receiver gets 1 with 50% probability and 0 with 50% probability - it looks like purely random noise.
To recover the message, the receiver has to know the result of measurements done at the sender - those results can be transferred in classical ways (electromagnetic waves, mail, avian carriers... does not matter). They alone also look like purely random noise. This is the 100% security part - it does not help you to intercept the classical data transfer.
Only the combination of both - the teleported state and the classical data stream - allows a reconstruction of the message.
If you want to transmit quantum states, the idea stays the same. You are not allowed to measure the transmitted particle (in the relevant parameter) as this will destroy the quantum state, but you still need the classical information path to prepare this state correctly.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
