Thread Closed
Mutually exclusive/independent events
Share Thread
May17-05, 02:20 PM   #1
Can someone please explain to me what the difference is between these two terms (in words, not maths)?
If A and B are mutually exclusive events, then A and B can't both happen at the same time. Is that right? What's the difference between that and if A and B were independent?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
May17-05, 02:51 PM   #2
Coin flip example:
One flip: Heads or Tails are mutually exclusive events
Two flips: The outcome of each flip is independent.
May17-05, 03:55 PM   #3
That sort of makes sense, thanks.
May17-05, 04:44 PM   #4
Recognitions:
Gold Membership Gold Member
Quote by Nylex
Right.
For starters, there is a link between mutually exclusive events- they can't both happen at once. However, there is no link between independent events- they don't effect each other at all. It might be easier to understand if you also consider non-mutually-exclusive events and dependent events.
If I draw one card from a deck, drawing an ace and drawing a king are mutually exclusive events- a single card cannot be both an ace and a king. However, drawing an ace and drawing a spade are not mutually exclusive events- a single card can be both an ace and a spade.
If I draw one card, return that card to the deck, and then draw another card, the draws are independent of each other- the sample space is the same for both draws because I returned the first card to the deck. If I draw one card, but do not return that card to the deck, and then draw another card, these events are dependent- the sample space is different since I didn't return the first card to the deck. Say I drew an ace the first time. Then there is one less card and one less ace in the deck, so the probabilities for the second draw have changed.
So mutually exclusive events are contrasted with non-mutually-exclusive events, asking whether one event excludes the other. Independent events are contrasted with dependent events, asking whether one event effects the probability of the other.
May18-05, 02:02 AM   #5
Thanks, honestrosewater, that's also good .
Thread Closed
Similar discussions for: Mutually exclusive/independent events
Thread Forum Replies
Independent event and mutually exclusive event Calculus & Beyond Homework 3
Probability: mutually exclusive vs. disjoint events Calculus & Beyond Homework 1
matter and space-time mutually exclusive? General Physics 5
Quest mutually exclusive events? Calculus & Beyond Homework 4
mutually exclusive and exclusive Set Theory, Logic, Probability, Statistics 3
