Can I Pursue a Physics PhD After Distance Learning in India?
Completing a graduation and Master's degree through distance education in India may impact eligibility for pursuing a Ph.D. Generally, traditional brick-and-mortar (B&M) institutions are preferred for Master's degrees, as they are viewed more favorably in Ph.D. applications. In the U.S., Master's and Ph.D. programs are often integrated, and many students do not earn a separate Master's degree. If a distance Master's is pursued, it may not be recognized in the same way, and students might have to start anew in a Ph.D. program, taking introductory courses and qualifying exams regardless of prior education.
thermodynamics
can I make myself eligible for pursuing Ph.D if I compltee graduation and Masters from some distance course...
Currently I am in India
I'm not sure how getting a master through distance education would look on potential Ph.D. applications. Generally, if it can be avoided, and you can do a M.S. at a B&M institution with a good reputation, I would advise doing that.
thank you :)
Usually in the U.S. the Masters and PhD are not split and most don't even get a Masters (unless they decide they are not going to continue on, some manage to nab a Masters and then leave). It's basically one program. The online Masters (and I'm not sure there is such a thing for physics) won't count for anything, you'll start fresh at the PhD program and still have to take all the intro course and take the qualification exams after the first year or two.
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
I'm going to make this one quick since I have little time. Background: Throughout my life I have always done good in Math. I almost always received 90%+, and received easily upwards of 95% when I took normal-level HS Math courses. When I took Grade 9 "De-Streamed" Math (All students must take "De-Streamed" in Canada), I initially had 98% until I got very sick and my mark had dropped to 95%. The Physics teachers and Math teachers talked about me as if I were some sort of genius. Then, an...
