Neutralizing Alcohol in Drinks: Is it Possible?
  • Thread starter Thread starter etmax
    Alcohol
The discussion centers on the possibility of neutralizing alcohol in beverages like wine or beer without compromising their quality. Participants question whether it is feasible to chemically alter these drinks to create non-alcoholic versions by using specific reagents or processes. There is skepticism about finding a reagent that selectively reacts with ethanol while preserving the beverage's characteristics. Concerns are raised about the potential for undesirable transformations, such as the conversion of ethanol to acetic acid, which would ruin the drink's flavor. The reverse osmosis method, commonly used in producing non-alcoholic beers, is mentioned as a possible solution, though there are fears that removing alcohol could lead to the precipitation of other substances and a significant change in taste, making the resulting product undrinkable.
etmax
This question is about neutralising alcohol in the bottle, not in the body or an attempt to get rid of a hangover.
So is it possible to turn an alcoholic beverage such as wine or beer into a light or non-alcoholic version by adding the appropriate chemicals and waiting for the reaction to complete?
Maybe by running it through a catalytic filter of some description if direct reaction isn't feasible?
Chemistry news on Phys.org
I am not aware of any reagent selective enough to react with ethanol only.
Thanks, do you know of any reagents that would at least leave the wine as recognisably wine :smile: as opposed to turning it into Heaven knows what ?
As stated before, there is really no feasible way to separate out the ethanol and leave the wine or beer in good condition.
I'm not sure what you're referring to when you say , but I can only imagine it is the transformation from ethanol to acetic acid. In this transition ethanol is oxidized, and in essences the drink no longer contains alcohol, though it now wreaks of acetic acid (vinegar) and has been thoroughly ruined.
No idea about reagents, but I wonder if reverse osmosis process (similar to that used to make non-alcohol beers) won't work.
Somehow I am afraid after removing the alcohol some of the substances dissolved in wine will precipitate out, and the taste will change substantially. Plus, ethanol itself is most likely responsible for part of the taste, so whatever is left can be undrinkable.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
14K
12K
