Solving Infinite Series: a_n = \frac{2n}{3n+1}
The discussion centers on determining the convergence of the sequence a_n = 2n/(3n+1). Participants clarify that this is a sequence, not a series, and suggest dividing the numerator and denominator by n to analyze the limit as n approaches infinity. The limit simplifies to 2/(3+1/n), which approaches 2 as n increases, indicating that the sequence does not converge to 0. For series convergence, it is emphasized that the sequence must converge to 0 for the series to converge. Overall, the sequence a_n diverges since it does not meet the necessary condition for series convergence.
ziddy83
I'm having a little trouble with the following problem. here it is...
Determinte whether a_n is convergent for...
How would i go about solving this? Can i just simply take the limit and use L'Hospital's rule to see if it diverges or converges? Or is it a little more complicated than that? I am asking this because in this section we're studying geometric series, and that doesn't look like a geo series to me since n is not in the exponent. Any help would be appreciated, thanks.
hello there
that aint a series, its a sequence
well to find if a_n is convergent, you would want to see what happens as n goes to infinity, and to do that divide the numerator and the denominator by the highest power in a_n, and I am sure you should know what happens to 1/n as n goes to infinty
steven
one more thing
if it is a series i would use either the
comparision test
or the
limit comparision test
steven
Series or sequence?
You don't need anything as complicated as L'Hospital's rule to determine this. If you mean the sequence \frac{2n}{3n+1}, just divide both numerator and denominator by n to get \frac{2}{3+\frac{1}{n}}. What happens to that as n goes to infinity?
If you mean the series \Sigma_{n=1}^{\infty}\frac{3n}{3n+1}, that's also easy after you know the limit of the sequence- in order that the series \Sigma a_n converge, the sequence {an} must converge to 0.
