Thread Closed
Strain rate effects on steel strength
Share Thread Thread Tools
Jul28-05, 08:42 AM   #1
I was wondering exactly how yield and tensile strength increases with increasing levels of strain rate for a typical steel grade? I understand dislocations are generated during straining (work hardening), but what happens at higher strain rates which increases the strength?
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Jul28-05, 11:04 AM   #2
Admin
Quote by SteveO
The effect of increasing yield and tensile strength with increasing strain/strain rate is observed in many, if not most, metals, and even polymers.
In metals, this would have to do with the rate of dislocation/defect generation and dislocation pile-up. The dislocations diffuse through the crystal structure (from inside grains to grain boundaries). If the rate of dilocation generation exceeds the rate at which the diffuse to gb, then the dislocation density has to increase, which causes an increase in strength.
In addition, dislocations may cancel, but if the do not diffuse fast enough, they will not cancel.
Try this paper Adams, Kenneth Hoyt (1965-05-21) Dislocation mobility and density in zinc single crystals
Thread Closed
Thread Tools
Similar Threads for: Strain rate effects on steel strength
Thread Forum Replies
Strength Coefficient and Strain-Hardening Exponent Mechanical Engineering 1
Comparing strength of channel versus flat steel General Engineering 1
Strength Coefficient and Strain-Hardening Exponent Engineering, Comp Sci, & Technology Homework 1
Impact Strength (mild steel tubing) General Engineering 1
Stress/Strain With Steel Introductory Physics Homework 1
