Need Help with Trigonometry Homework | Simplifying cos2xsin2x-cos2x
  • Thread starter Thread starter TonyC
    Trigonometry
The discussion revolves around simplifying the expression cos(2x)sin(2x) - cos(2x). The original poster mistakenly concludes that the simplification results in cos(2x), which is incorrect. Participants suggest factoring cos(2x) or applying the double angle formula to achieve a correct simplification, ultimately leading to the expression -cos^4(x). The conversation highlights the challenges faced when returning to mathematics after a long absence, emphasizing the need for clarity in understanding trigonometric identities. Overall, the thread provides insights into common pitfalls in trigonometric simplification.
TonyC
I am having extreme difficulty with my Trigonometery homework.
In particular, When I simplify the expression:
cos2xsin2x-cos2x
I come up with cos2x.
This is obviously incorrect. Where am I going wrong?
Well it depends on how you want to simplify. Do you need to get rid of the double angles or just to 'shortes' possible way of expression?
\cos{2x} is indeed wrong...
You could factor \cos{2x}, don't know if that's what you want.
You could also use the double angle formula backwards on \cos{2x}\sin{2x} to get \frac{\sin{4x}}{2}
I should have written it:
cos(squared) x sin(squared) x - cos(squared) x
shortest way
What do you mean? Now you say \cos ^2 x\sin ^2 x - \cos ^2 x.
That's not the same as your initial expressions :confused:
You mean that's what you actually meant? What did you try already then?
Still trying figure out how to get all of the expressions to translate into typed text...sorry.
I cos(sq'd)x-cos(sq'd)x
then 1-sin(sq'd)=cos(sq'd)X
this is why I came up with cos(sq'd)x
Well, I'd do about the same but you get something different:
\cos ^2 x\sin ^2 x - \cos ^2 x = \cos ^2 x\left( {1 - \cos ^2 x} \right) - \cos ^2 x = \cos ^2 x - \cos ^4 x - \cos ^2 x = - \cos ^4 x
I see the step I missed. Thank you very much.
School is hard when you have been out of it for 18 years. :smile:
I can imagine you need some freshing up :wink:
