Freight Car Velocity: Newton's 1st Law Explained
  • Thread starter Thread starter mini_mia
    Car Velocity
The discussion revolves around a physics problem involving a railway freight car carrying sand, which is traveling at a uniform velocity on a straight level track. A leak develops, causing sand to pour out. Participants are exploring the implications of Newton's 1st Law and how the loss of mass affects the car's velocity.
  • The original poster attempts to understand how the loss of sand affects the velocity of the freight car, referencing Newton's 1st Law. Some participants question the implications of mass loss on velocity and momentum, while others suggest considering Newton's 2nd Law in relation to the situation.
The discussion is active with participants exploring different interpretations of Newton's laws. Some guidance has been offered regarding the relationship between mass, velocity, and momentum, but there is no explicit consensus on the effects of the sand falling out.
Participants are operating under the assumption that there are no external forces acting on the car, which is a critical point of discussion. The implications of the sand's velocity and its momentum are also under consideration.
mini_mia
Hey guys!
I was wondering if I could get some help with this question:
A railway freight car that is carrying sand is traveling at a uniform velocity on a straight level track. A leak develops in the flat bottom, and the sand begins to pour out of a hole onto the ground. Assuming there aren't any external forces on the car (including friction), does the velocity of the car decrease, increase or remain the same?
According to Newton's 1st law, it says that the velocity of an object will remain constant unless it's acted upon by an external or unbalanced force, which there isn't any in this question. However, I am a bit confused about the sand falling out. Do this affect the velocity of the car? Thanks if you can help me!
What does Newton's second law say about this situation? Remember that Newton's second law can be written as a relation between the net force and the rate of change of momentum.
Okay, so Newton's 2nd Law in terms of momentum is Δp = F Δt , which is also
F Δt = m Δv.
So in isolating velocity from the formula, as the mass decreases, the velocity would increase?
That is incorrect. Yes the mass of the sand is leaving the car, but the sand itself has a velocity and therefore takes it momentum with it.
  • · Replies 32 ·
  • · Replies 19 ·
