Using Sigma Notation to Prove \sum_{k=M}^{N} 2^{-k} = 2(2^{-M} - 2^{-N})
The discussion revolves around using sigma notation to prove the equation \(\sum_{k=M}^{N} 2^{-k} = 2(2^{-M} - 2^{-N})\). The subject area includes series and sequences, particularly geometric series.
  • Participants explore different methods to manipulate the sigma notation and expand the sums involved. Some attempt to express the sums in terms of known series, while others question the validity of the proposed equation by testing specific values.
The discussion is ongoing, with various participants providing hints and alternative approaches. Some express confusion about the steps taken, while others suggest methods involving geometric series. There is no clear consensus on the correctness of the original equation, as some participants point out potential errors in the reasoning.
Participants note that the problem may have inherent errors, and there are discussions about the implications of negative indices in the context of the series. The original poster and others are attempting to reconcile their findings with the proposed equation.
dekoi
Show that:
[tex]\sum_{k=0}^{N} a_k = \sum_{k=M}^{M+N} a_{k-M}[/tex]
I did this, my answer is:
[tex]\sum_{k=0}^{N} a_k = a_0 + a_1 + a_2 + ... + a_N[/tex]
[tex]\sum_{k=M}^{M+N} a_{k-M} = a_{M-M} + a_{M+1-M} + a_{M+2-M} + ... + a_{M+N-M} = a_0 + a_1 + a_2 + ... + a_N[/tex]
Now, I have to use this to prove that:
[tex]\sum_{k=M}^{N} 2^{-k} = 2(2^{-M} - 2^{-N})[/tex]
So, I tried expanding the sum:
[tex]\sum_{k=M}^{N} 2^{-k} = 2^{-M} + 2^{-(M+1)} + 2^{-(M+2)} + ... + 2^{-N}[/tex]
I factored out some 2's:
[tex]\sum_{k=M}^{N} 2^{-k} = 2^{-M}2^{0} + 2^{-M}2^{-1} + 2^{-M}2^{-2} + ... + 2^{-M}2^{-N} = 2^{-M}(2^{0} + 2^{-1} + 2^{-2} + ... + 2^{-N})[/tex]
Which I'm assuming is equal to some other sum:
[tex]\sum_{k=M}^{N} 2^{-k} = 2^{-M}(\sum_{i=0}^{N} 2^{-i})[/tex]However, I don't know how to continue this. Any suggestions?
Hint: [tex]\sum_{k=M}^{N} 2^{-k} = \sum_{k=0}^{N} 2^{-k}-\sum_{i=0}^{M-1} 2^{-i}[/tex]
That doesn't seem to work.
I get:
[tex]\sum_{k=M}^{N} 2^{-k} = (2^{0} + 2^{-1} + 2^{-2} + ... + 2^{-N}) - (2^{0} + 2^{-1} + 2^{-2} + ... + 2^{-M + 1}[/tex]
[tex]= 2^{-N} - 2^{-M+1} = 2^{-N} + 2^{-M}2^{1}[/tex]
Which will not equal to : [tex]2(2^{-M} - 2^{-N})[/tex]
[tex]a_{M}+a_{M+1}+\cdot\cdot\cdot+a_{N-1}+a_{N}=\left( a_{M}+a_{M+1}+\cdot\cdot\cdot+a_{N-1}+a_{N}\right) + \left[ \left( a_{0}+a_{1}+\cdot\cdot\cdot+a_{M-1}\right) - \left( a_{0}+a_{1}+\cdot\cdot\cdot+a_{M-1}\right) \right][/tex]
[tex]\left[ \left( a_{M}+a_{M+1}+\cdot\cdot\cdot+a_{N-1}+a_{N}\right) + \left( a_{0}+a_{1}+\cdot\cdot\cdot+a_{M-1}\right) \right] - \left( a_{0}+a_{1}+\cdot\cdot\cdot+a_{M-1}\right) = \left( a_{0}+a_{1}+\cdot\cdot\cdot+a_{N-1}+a_{N}\right) - \left( a_{0}+a_{1}+\cdot\cdot\cdot+a_{M-1}\right)[/tex]
Wait, we posted at the same time.
Read my previous post, I edited it.
I think you mean:
[tex]\sum _{k=M} ^N = 2(2^{-M}\mathbf{)} - 2^{-N}[/tex]
Anyways, I don't know how you'd prove this using what you proved first, but you can prove this if you know that:
2n - 1
= 2n - 20
= 2n + 0 + 0 + ... + 0 - 20
= 2n + (-2n-1 + 2n-1) + (-2n-2 + 2n-2) + ... + (-21 + 21) - 20
= (2n + 2n-1 + ... + 21) - (2n-1 + 2n-2 + ... + 20)
= 2(2n-1 + 2n-2 + ... + 20) - (2n-1 + 2n-2 + ... + 20)
= (2n-1 + 2n-2 + ... + 20)
No, no... I wrote the sum correctly.
AKG is right: [tex]\sum _{k=M} ^N 2^{-k}= 2(2^{-M}\mathbf{)} - 2^{-N}[/tex]
Well it's false so good luck proving it:
M = 3, N = 4
[tex]\sum_{k=3}^{4} 2^{-k} = 2(2^{-3} - 2^{-4})[/tex]
[tex]2^{-3} + 2^{-4} = 2(2^{-3} - 2^{-4})[/tex]
[tex]\frac{1}{8} + \frac{1}{16} = 2(\frac{1}{8} - \frac{1}{16})[/tex]
[tex]\frac{3}{16} = 2(\frac{1}{16})[/tex]
[tex]3 = 2[/tex]
Good luck.
Here's one way to do it:
the later sums are geometric... recall that the partial sum thereof is
[tex]1+r+r^2+r^3+\cdot\cdot\cdot+r^n=\frac{1-r^{n+1}}{1-r}[/tex]
This is going to be tricky... especially since the question I'm given has an error in it itself :S.
I guess I will have to try your methods.
Thank you AKG and benorin.
I'll get back to you if I have any problems.
Well, that is the partial sum for a positive n, but in my case-- there is a negative n.
What is the partial sum for :
[tex]\sum_{i=0}^{N} 2^{-i}[/tex]
[tex]2^{-i}=\left( 2^{-1}\right)^{i}=\left( \frac{1}{2}\right)^{i}[/tex]
hence [tex]\sum_{i=0}^{N} 2^{-i}= \sum_{i=0}^{N}\left( \frac{1}{2}\right)^{i} = \frac{1-\left( \frac{1}{2}\right)^{N+1}}{1-\frac{1}{2}}=2\left( 1-2^{-(N+1)}\right)[/tex]
do likewise for [tex]\sum_{i=0}^{M-1} 2^{-i}[/tex] and subtract.
Why am I doing likewise for [tex]\sum_{i=0}^{M-1} 2^{-i}[/tex] ?
This was my last step: [tex]\sum_{k=M}^{N} 2^{-k} = 2^{-M}(\sum_{i=0}^{N} 2^{-i})[/tex]
the last term of the sum on left is [tex]2^{-N}[/tex] on the right the last term is [tex]2^{-(N+M)}[/tex], so their not equal.
do likewise for [tex]\sum_{i=0}^{M-1} 2^{-i}[/tex], that is
[tex]\sum_{i=0}^{M-1} 2^{-i}= \sum_{i=0}^{M-1}\left( \frac{1}{2}\right)^{i} = \frac{1-\left( \frac{1}{2}\right)^{(M-1)+1}}{1-\frac{1}{2}}=2\left( 1-2^{-M}\right)[/tex]
and subtract:
[tex]\sum_{k=M}^{N} 2^{-k} = \sum_{k=0}^{N} 2^{-k}-\sum_{i=0}^{M-1} 2^{-i}= 2\left( 1-2^{-(N+1)}\right) - 2\left( 1-2^{-M}\right) = 2^{1-M}-2^{-N}[/tex]
Sorry to be short, but got to go...
I don't quite understand.
I realize that your method is correct, but I don't understand why.
  • · Replies 17 ·
