Why Does DNA Replication Require a Lagging Strand?
In summary: The major constraint that was likely involved in the evolution of the lagging-strand synthesis mechanism was the constraint of ancestry.
SAT2400
69
1 hard(?!) Biology Question!HELP! :/
If life had been "intelligently" design, and if an important design principle is conservation of material and efficiency of process, we would not expect DNA replication to involve the crazy, complex, intricate, Byzantine mechanism for lagging strand synthesis. For example, one way to design the process is to have both strands continuously synthesized. However, evolution is responsible for producing the lagging-strand synthesis mechanism, and evolution is notoriously constrained by ancestry. That is, because evolution works by modifying parts and processes that existed previously in an ancestor, what can exist in the descendent is limited by what existed previously. In general, evolutionary biologists call this "constraint" or "phylogenetic constraint" What is the major constraint that was likely involved in the evolution of the lagging-strand synthesis mechanism? (That is, what was the constraint most likely involved in limiting continuous polymerization to occur on only one strand at the replication fork?)
A. An RNA primer is required to start polymerization.
B. The DNA has to be unwound by a helicase, and this unwinding occurs in one rotational direction.
C. DNA polymerases only attach nucleotide monomers to the 3' end of the molecule.
D. The density of single-stranded binding proteins differs between the two strands.
E. Nucleotides have a particular polarity, with a phosphate at the 5' end and a 3' hydroxyl at the 3' end.
Biology,,,gene replication?
I think it's C..because 3' end is the part that should be open?!
Please helP~! thanks!
Yeah, pretty much. The helicase unwinds the DNA, resulting in two single strands of DNA running in opposite directions at the fork. If DNA synthesis can only proceed in one direction, then only one of these can be continuously synthesized, since the other strand must be being unwound in the wrong direction.
yes, C is the most likely answer b/c the DNA ploymerase inherited from ancestors can only go can only synthesize in the 5' to 3' direction. one strand, the leading, is going in the correct direction so there is no problem. but since the other strand is running in the opposite direction, cells have adapted to this problem by causing the Oozaki fragments to be formed and go "upstream" of the rest of the synthisis
Isn't the 5' -3' limitation a consequence of the kinetics of the reaction, as oppose to an evoluitionary limitation?
Yes, it is a consequence of the reaction mechanism. The point of the "evolutionary limitation" is that evolution works with what it's got. What we -have- is a 5' -> 3' elongation mechanism, not a 3' -> 5' one. So this entire machinery surrounding Okazaki fragments gets invented to deal with the fact that we have to mimic 3'->5' elongation with a 5' -> 3' mechanism.
Ultimately that whole preamble doesn't really have much to do with the answer.
What is the definition of biology?
Biology is the scientific study of living organisms, including their physical structure, chemical processes, molecular interactions, development, and evolution.
What is the difference between a prokaryotic and eukaryotic cell?
Prokaryotic cells are smaller and simpler than eukaryotic cells, and do not have a nucleus or membrane-bound organelles. Eukaryotic cells, on the other hand, are larger and more complex, with a nucleus and various organelles that perform specific functions.
What is the process of photosynthesis?
Photosynthesis is the process by which plants, algae, and some bacteria convert light energy from the sun into chemical energy in the form of glucose. This process involves the absorption of light by chlorophyll, which is then used to convert carbon dioxide and water into glucose and oxygen.
What is the role of DNA in genetics?
DNA (deoxyribonucleic acid) is the genetic material that carries the instructions for the development and function of all living organisms. It contains the genetic code that determines an organism's traits and is passed down from parents to offspring.
What is the scientific method and how is it used in biology?
The scientific method is a systematic approach to answering questions and solving problems through observation, experimentation, and analysis. In biology, it is used to investigate and understand the natural world, make predictions, and develop theories about living organisms.
  • Biology and Medical
54K
19K
  • Other Physics Topics
