-206.q3.2 method of integrating factor
In summary, to solve the first order linear differential equation $\frac{dy}{dx}+5y=10x$, we can use the method of integrating factor by multiplying both sides by $\exp\left(\int 5\,dx\right)$ and then integrating both sides with respect to $x$. This allows us to rewrite the ODE as $\frac{d}{dx}\left(\exp\left(\int 5\,dx\right)y\right)=10x\exp\left(\int 5\,dx\right)$.
karush
MHB
3,269
$\tiny{206.q3.2}\\$
$\textsf{3. use the method of integrating factor}\\$
$\textsf{to find the general solution to the first order linear differential equation}\\$
\begin{align}
\displaystyle
\end{align}
$\textit{clueless !}$
Given a first order linear ODE of the form:
\(\displaystyle \d{y}{x}+f(x)y=g(x)\)
We can use an integrating factor $\mu(x)$ to make the LHS of the ODE into the derivative of a product, using the special properties of the exponential function with regard to differentiation. Consider what happens if we multiply though by:
\(\displaystyle \mu(x)=\exp\left(\int f(x)\,dx\right)\)
We get:
\(\displaystyle \exp\left(\int f(x)\,dx\right)\d{y}{x}+\exp\left(\int f(x)\,dx\right)f(x)y=g(x)\exp\left(\int f(x)\,dx\right)\)
Now, let's use:
\(\displaystyle F(x)=\int f(x)\,dx\implies F'(x)=f(x)\)
And we now have:
\(\displaystyle \exp\left(F(x)\right)\d{y}{x}+\exp\left(F(x)\right)F'(x)y=g(x)\exp\left(F(x)\right)\)
Now, if we observe that, via the product rule, we have:
\(\displaystyle \frac{d}{dx}\left(\exp(F(x))y\right)=\exp\left(F(x)\right)\d{y}{x}+\exp\left(F(x)\right)F'(x)y\)
Then, we may now write our ODE as:
\(\displaystyle \frac{d}{dx}\left(\exp(F(x))y\right)=g(x)\exp\left(F(x)\right)\)
Now, we may integrate both sides w.r.t $x$.
So, in the given ODE:
\(\displaystyle \d{y}{x}+5y=10x\)
We identify: \(\displaystyle f(x)=5\)
And so we compute the integrating factor as:
\(\displaystyle \mu(x)=\exp\left(5\int\,dx\right)=\)?
wow that was a great help. but I'll have go thru this tonmorro ...
ok, got it, but have never come up with that😎
1. What is the "-206.q3.2 method of integrating factor"?
The "-206.q3.2 method of integrating factor" is a mathematical technique used to solve first-order ordinary differential equations. It involves finding a suitable integrating factor that can be multiplied to both sides of the equation to simplify the integration process.
2. How does the "-206.q3.2 method of integrating factor" work?
The method involves finding an integrating factor by taking the inverse of an integrating factor function, which is derived from the original equation. This factor is then multiplied to both sides of the equation, making it easier to integrate and solve for the unknown variable.
3. When is the "-206.q3.2 method of integrating factor" used?
This method is typically used when solving first-order linear differential equations with non-constant coefficients. It is particularly useful when the equation is not easily solvable by other methods, such as separation of variables or substitution.
4. What are the advantages of using the "-206.q3.2 method of integrating factor"?
One of the main advantages of this method is that it can be applied to a wide range of first-order differential equations with non-constant coefficients. It also simplifies the integration process and can lead to a more precise and accurate solution.
5. Are there any limitations to the "-206.q3.2 method of integrating factor"?
While this method can be very useful, it is not always applicable to all types of differential equations. It also requires some knowledge of integrating factor functions and may involve more steps than other methods. Additionally, it may not be effective for solving higher-order differential equations.
  • Differential Equations
