311.1.3.19 find h and k in the system
  • MHB
  • Thread starter karush
  • Tags
    System
In summary, the system has a unique solution (intersection) when h is not equal to 2 and many solutions (same line) when h is 2 and k is not 8. It has no solution (parallel) when h is 2 and k is 8.
karush
MHB
3,269
$\tiny{311.1.3.19}$
find h and k such that the system has, no solution (parallel) ,unique solution (intersection) , many solutions (same line)
$\begin{array}{rrr}
x_1+hx_2&=2&(1)\\
4x_2+8x_2&=k&(2)
\end{array}$
by observation if h=2 then $k=\mathbb{R}, k\ne 8$ for parallel
if $h\ne 2$ then intersection
if $h=2$ and $k=8$ many solutions
I presume that you solved the equations:
Multiply the first equation by 4 to get \(\displaystyle 4x_1+ 4hx_2= 8\).
Subtract that from the second equation, \(\displaystyle 4x_1+ 8x_2= k\) to get \(\displaystyle (8- 4h)x_2= k- 8\).
Solve for \(\displaystyle x_2\) by dividing by 8- 4h: \(\displaystyle x_2= \frac{k- 8}{8- 4h}\). As long as 8- 4h is not 0, which means h is not 2, there is a unique answer. (There are two intersecting lines.)
If h= 2 and k= 8 the equation is \(\displaystyle 0x_2= 0\) which is true for all \(\displaystyle x_2\) so there are infinitely many solutions. (There is only one line described by both equations.)
If h= 2 and k is not 8, the equation is \(\displaystyle 0x_2= k- 8\) which is NOT true for any \(\displaystyle x_2\). There is no solution. (There are two parallel lines.)
That is what you have. Well done!
1. What is the meaning of "311.1.3.19 find h and k in the system"?
The phrase "311.1.3.19 find h and k in the system" refers to a mathematical problem that involves finding the values of 'h' and 'k' in a given system or equation. This type of problem is commonly encountered in algebra and calculus, and it requires the use of various techniques and formulas to solve.
2. How do I solve for h and k in a system?
To solve for h and k in a system, you can use a variety of techniques such as substitution, elimination, or graphing. The specific method used will depend on the type of system and the given equations. It is important to carefully analyze the system and choose the most appropriate method for solving.
3. What are the steps to find h and k in a system?
The steps to find h and k in a system will vary depending on the method used to solve the system. Generally, the first step is to analyze the given equations and determine the type of system. Then, you can choose the appropriate method and apply it to the system to find the values of h and k.
4. Can I use a calculator to find h and k in a system?
Yes, you can use a calculator to find h and k in a system. However, it is important to note that calculators may not always provide exact solutions and may round off the values. It is recommended to also check your solutions by hand to ensure accuracy.
5. What are some real-life applications of finding h and k in a system?
Finding h and k in a system is a fundamental concept in mathematics and has many real-life applications. For example, it can be used to solve problems in physics, engineering, and finance. It can also be used to analyze data and make predictions in various fields such as economics and biology.
  • Linear and Abstract Algebra
