-412.12.1 basis of kernel
In summary: Finally multiply each element by $1$ to get a basis for $D^4-2D^3-3D^2$. In summary, the basis for the kernel of $D^4-2D^3-3D^2$ is the set of functions $e^{3x}$, $e^{-x}$ and $1$.
karush
MHB
3,269
ok I am new to this basis of kernel and tried to understand some other posts on this but they were not 101 enough
Find the basis for kernel of the differential operator $D:C^\infty\rightarrow C^\infty$,
$D^4-2D^3-3D^2$
this can be factored into
$D^2(D-3)(D+1)$
$D^4-2D^3-3D^2$
$D^2(D-3)(D+1)$
First, you need to work out what the question is asking for. The differential operator $D:C^\infty\rightarrow C^\infty$ take a smooth function $y = f(x)$ and differentiates it. The kernel of $D$ is the set of functions that it takes to zero, namely the constant functions. So a basis for the kernel of $D$ would consist of a single element, the constant function $1$.
But what the question is actually asking for is not the kernel of $D$, but the kernel of $D^4-2D^3-3D^2$. Using the factorisation $D^4-2D^3-3D^2 = D^2(D-3)(D+1)$ (and the fact that those factors commute with each other), what you need to do is to find the kernel of each separate factor.
For example, the kernel of $D-3$ consists of functions $y=f(x)$ such that $(D-3)y = 0$, in other words $\frac{dy}{dx} - 3y = 0$. The solution of that differential equation consists of multiples of $e^{3x}$, so a basis for the kernel of $D-3$ would be the function $e^{3x}$. Now do the same for the other two factors $D^2$ and $D+1$, to get a basis for $D^2(D-3)(D+1)$.
1. What is the "-412.12.1 basis of kernel"?
The "-412.12.1 basis of kernel" refers to the specific version and release of the kernel, which is the core component of an operating system. It is a set of essential programs and routines that manage the system's resources and provide a bridge between the hardware and software.
2. What does the "-412.12.1" in "-412.12.1 basis of kernel" represent?
The "-412.12.1" in "-412.12.1 basis of kernel" represents the version number of the kernel. The first number (4) indicates the major version, the second number (12) indicates the minor version, and the third number (1) indicates the patch level. This version numbering system helps to track changes and updates to the kernel.
3. Why is the "-412.12.1 basis of kernel" important?
The "-412.12.1 basis of kernel" is important because it serves as the foundation of the operating system. It is responsible for managing the system's resources, such as memory and hardware devices, and providing a platform for software programs to run. Any changes or updates to the kernel can significantly impact the performance and stability of the entire operating system.
4. How is the "-412.12.1 basis of kernel" developed and maintained?
The "-412.12.1 basis of kernel" is typically developed and maintained by a community of developers and engineers. They work together to write, test, and debug the code for the kernel, ensuring that it is stable, secure, and efficient. The development and maintenance of the kernel also involve regular updates and bug fixes to improve its functionality.
5. Can the "-412.12.1 basis of kernel" be customized or modified?
Yes, the "-412.12.1 basis of kernel" can be customized or modified to suit specific needs. Many operating systems, such as Linux, allow users to choose from different kernel versions or even make changes to the source code. However, modifying the kernel requires advanced technical knowledge and should be done carefully to avoid compromising the stability and security of the system.
  • Linear and Abstract Algebra
  • Computing and Technology
