A question about the definition of 'set'
In summary: That said, in ZF set theory, elements of a set are always sets. In fact, all is sets. There are other set theories out there with elements that are not sets (but so-called urelements), but these are not...
  • #36
xxxx0xxxx said:
[tex]\mbox{A is a class} \Leftrightarrow \exists z( z \in A \vee A=\emptyset) [/tex]
As an aside, in NBG, both sides of the equivalence in NBG are tautological predicates of one variable (A).
  • #37
Yes, the convention is usually to drop the universal quantifier...
[tex] \forall A(\mbox{A is a class} \Leftrightarrow \exists z(z \in A \vee A = \emptyset)) [/tex]
All definitions are tautologies.
  • #38
No, I mean, for example,
A is a class​
is a tautology.
  • #39
A is a class​
is a tautology.
Well, that may be because you are not making a distinction between object language and metalanguage.
  • #40
There is no metalanguage in mathematics...
  • #41
What he is probably referring to an axiomatic formalization of the logical inferences within set theory, known as a metatheory, in which one could e.g. formally say "[itex]\phi[/itex] is unprovable" for a statement [itex]\phi[/itex] in set theory, whereas set theory can only say "[itex]\phi[/itex]" (or [itex]\neg \phi[/itex], or any combinations of conjunctions, negations, etc.. of set theoretical statements). A metalanguage consists of statements about statements in some axiomatic setting, like set theory. Such a metalanguage is necessary to be able to prove that certain things are unprovable in set theory, such as the continuum hypothesis, so called metatheorems. It is also used to prove that the axiom of choice is logically independent from ZF.
  • #42
What you wrote was a statement in the language of NBG, and you even stated it as "for NBG". If you mean something other than what you wrote, it's up to you to make that explicitly clear. It is not up to us to divine your intent, nor even to assume your being meaningful at all.
  • #43
Well, you need not divine much,
"A" is in the object language
"is a class" is a statement in the metalanguage.
"A is a class" is well-formed-formula by virtue of the definiens:
[tex] \exists z (z \in A \vee A = \emptyset) [/tex]
which is composed of nothing but elements of the object language.
  • #44
Seems pretty straightforward to me.
ZF can serve as a metalanguage for NBG, or any other model.
  • #45
I'd love to see some kind of proof for that...
  • #46
"is a class" is a predicate in the language of NBG. (the trivially true one, to be precise)
I have no idea how you manage to read it as a "statement" "in the metalanguage" or what you could possibly mean by such a claim.
(maybe... you just aren't familiar with forms of first-order logic that offer a richer syntax for doing routine logical tasks?)
That's not quite true -- I was wondering if you were thinking of an interpretation of NBG, and you were using "class" to refer not to the type of that name in NBG (actually, I think it's usually shortened to Cls) but some metatype you're interpreting it into. But, of course, if you were doing that "A is a class" would make no sense if A was a variable in the language of NBG.
  • #47
See the attached...
Moderator's note -- removed copyrighted material
  • #48
xxxx0xxxx said:
See the attached...
I don't see how that answers my question...
Firstly, your attachment assumes the existence of a inaccessible cardinal, which is a huge assumption. In fact it cannot be proven that ZFC+inaccessible cardinal is relatively consistent with ZFC. Thus it is an assumption I don't like to see.
Furthermore, a statement in ZFC is provable iff it is provable in NBG. Thus the assumption of a large cardinal seems to be a bit too much.
Also, you said that "any set theory can be phrased in terms of ZF". I have yet to see a proof for this. How would you phrase NF or MK in terms of ZF?
  • #49
See the attached...
http://matwbn.icm.edu.pl/ksiazki/fm/fm64/fm64126.pdf
Moderator's note: duplication of copyrighted material replaced with link to source
(article title: "Novak's result by Henkin's method")
  • #50
That doesn't answer the question...
  • #51
Well,
having failed to answer your question in which you replaced my word "model" with your word "rephrased," and shown why mathematics is very much like arguing "how many angels can fit on the head of pin?", I return to my original statement to the OP:
[tex]A \mbox{ is a set} \Leftrightarrow \exists z (z \in A \vee A = \emptyset) [/tex]
without any of the encumbrances peculiar to a particular theory of sets.
Best regards to all...
except those who absolutely have to have the last word...
  • #52
xxxx0xxxx said:
Well,
OK, sorry. Then provide a proof why ZF can be seen as model of other set theories? Or whatever it is you meant.
Let me remind you how mathematics works: we work with clear definitions and we prove things. Therefore, if we make a statement, then the statement should be precise and provable. If you actually think that mathematics is like arguing "how many angels can fit on the head of a pin", then I'm sorry but you haven't understood mathematics at all.
Doesn't work in NBG.
It's not about having the last word, it's about correct obviously false statements.
  • #53
Ah, we've moved onto the "try to drown them in a deluge of material without any explanation or attempting to connect it to the issue at hand" stage of crackpottery. I think now's a good time to close it.
  • Topology and Analysis
