Achilles and the Supremum
  • Thread starter Rasalhague
  • Tags
    Supremum
In summary, KG Binmore discusses Zeno's paradox of Achilles and the tortoise in order to introduce the concept of suprema for sets of real numbers. This paradox arises from the idea that Achilles, who runs faster than the tortoise, can never catch up to it because the tortoise always has a head start. Binmore's solution to this paradox involves considering the smallest real number larger than all of the numbers representing the distances Achilles has to cover. This solution relies on the existence of the real numbers, specifically the continuum property. However, the question arises as to whether Achilles can still catch the tortoise without this property, using a race track of rational numbers. This raises the paradox of whether there can exist combinations of parameters where Achilles can
Rasalhague
1,387
KG Binmore talks about Zeno's paradox of Achilles and the tortoise to motivate the idea of suprema for sets of real numbers:
Since Achilles runs faster than the tortoise, the tortoise is given a head start of x0 feet. When Achilles reaches the point where the tortoise started, the tortoise will have advanced a bit, say x1 feet. [...]
The simplest way to resolve this paradox is to say that Achilles catches the tortoise after he has run x feet, where x is the 'smallest real number larger than all of the numbers x0, x0 + x1, x0 + x1 + x2, ...' [...]
This solution, of course, depends very strongly on the existence of the real number x.
i.e. on what he calls the continuum property.
But can't Achilles can catch the tortoise even without the continuum property, e.g. on a race track of rational numbers? Let x be Achilles' position, and y that of the tortoise. Let u be Achilles' speed, and v that of the tortoise.
[tex]x = 0+ut;[/tex]
[tex]y = \frac{1}{2}+vt;[/tex]
[tex]x,y,u,v,t \in \mathbb{Q}.[/tex]
Let the race begin at t = 0. If u = 1, and v = 1/2, Achilles will catch the tortoise at x = y = 1.
Is the problem with [itex]\mathbb{Q}[/itex] that there exist combinations of parameters for which Achilles can pass the tortoise without at any time being at the same point as the tortoise? Is that the paradox which the real numbers, with their guarantee of a least upper bound, resolves?
Mathematics news on Phys.org
Yes, that's a very good insight into the problem.
But has nothing to do with Zeno's paradox.
Feel free to elaborate!
My question was about Binmore's use of the story of the race to motivate the idea of a least upper bound. I was trying to pin down what it is about a race along, say, the rational numbers (which lack the continuum property) that makes such a race paradoxical (to Binmore) in a way that a race along the real numbers is not (because they have the continuum property).
I can appreciate that Zeno may have used the story in a different way, and that for him perhaps the paradox lay simply in the idea of an infinity of intermediate points. Is this what you wanted to draw our attention to?
I find Binmore's use of Zeno's paradox to introduce the concept of suprema for sets of real numbers to be a clever and effective way to illustrate the importance of the continuum property. The paradox itself highlights the potential issues that can arise when dealing with infinite sets and the need for a mathematical framework that can handle them.
Binmore's solution relies on the existence of the real number x, which is the smallest real number larger than all of the numbers x0, x0 + x1, x0 + x1 + x2, and so on. This concept of a "least upper bound" is crucial in understanding the behavior of infinite sets and is a fundamental property of the real numbers. Without it, the paradox cannot be resolved.
The example provided by Binmore of a race track of rational numbers also highlights the limitations of using just rational numbers. While it is possible for Achilles to eventually catch the tortoise on this track, there are combinations of parameters where he can pass the tortoise without ever being at the same point as the tortoise. This is the paradox that the real numbers, with their guarantee of a least upper bound, can resolve.
In conclusion, the use of Zeno's paradox of Achilles and the tortoise to introduce the concept of suprema for sets of real numbers is a clever and effective way to illustrate the importance of the continuum property. It highlights the limitations of using just rational numbers and the need for a mathematical framework that can handle infinite sets.
1. What is the story of Achilles and the Supremum?
Achilles and the Supremum is a famous mathematical paradox that explores the concept of infinity. The story goes that Achilles, the fastest runner in all of Greece, is in a race against a tortoise. The tortoise is given a head start, and Achilles must catch up to it. However, every time Achilles reaches the point where the tortoise was, the tortoise has moved a small distance ahead. This pattern continues infinitely, leading to the question of whether Achilles can ever catch up to the tortoise.
2. Who came up with the paradox of Achilles and the Supremum?
The paradox of Achilles and the Supremum was first introduced by the Greek philosopher Zeno of Elea in the 5th century BC. However, it was later made famous by the mathematician Georg Cantor in the late 19th century.
3. What is the mathematical concept behind Achilles and the Supremum?
The mathematical concept behind Achilles and the Supremum is the concept of a limit. In this paradox, the distance between Achilles and the tortoise is divided into infinitely small segments, and the question is whether the sum of these segments can ever reach the distance between them.
4. How is the paradox of Achilles and the Supremum resolved?
The paradox of Achilles and the Supremum is resolved by understanding the concept of infinity and limits in mathematics. While Achilles may never catch up to the tortoise in a finite amount of time, in theory, he can reach the tortoise in an infinite amount of time.
5. What is the significance of Achilles and the Supremum in mathematics?
Achilles and the Supremum is a famous paradox that has sparked much debate and discussion in the world of mathematics. It highlights the complexities of infinity and challenges our understanding of limits. It has also led to the development of new mathematical theories and concepts, making it a significant topic in the field of mathematics.
  • General Math
  • Topology and Analysis
  • Calculus
  • Math Proof Training and Practice
