Active power dissipated by a resistor from DC to RF
The discussion centers on the power dissipated by a resistor at varying frequencies, particularly contrasting high frequencies with DC. At high frequencies, the power is calculated using a specific equation involving characteristic impedance and reflection coefficients, while at DC, the active power is derived from a different formula that does not incorporate these parameters. Participants debate the mathematical relationship between the two equations, highlighting that at DC, the characteristic impedance becomes indeterminate and does not contribute to power dissipation. It is noted that a smooth transition between the two equations is expected, but practical considerations complicate this transition due to the negligible impact of transmission line effects at very low frequencies. Ultimately, the conversation underscores the complexities of reconciling AC and DC power calculations in real-world applications.
aabbaa11
TL;DR Summary
My question is what is the connection between equations on the power dissipated by resistor in DC and high frequency?
Hello all PF members!
I was wondering about the power dissipated by resistor at high frequency which is:
##P=Re\left \{ U\cdot I^{*} \right \}=Re\left \{ \frac{\left |V^{+} \right |^{^{2}}}{2\left |Z_{c} \right |}\cdot (1-\left |\Gamma \right |^{2} )\right \}##, (1)
where:
##Z_{c}## - characteristic impedance of the waveguide (transmission line) = ##\sqrt{\frac{R_{c}+ j\omega L_{c}}{G_{c}+ j\omega C_{c}}}##
##V^{+} ## - amplitude of incident wave (to the resistor)
##\Gamma## - reflection coefficient = ##\frac{Z_{L}-Z_{c}}{Z_{L}+Z_{c}}##, where ##Z_{L}## is load impedance.
These equations work fine at high frequency. The problem (and my question) is about the case of lower frequency and DC. When the frequency is going down the ##\left | Z_{c} \right |## is going to +inf, as well as ##1-\left |\Gamma \right |^{2} ## which is going to 0. Thus, the total active power is equal to 0 at DC. I can assume, that equation (1) represents the active power delivered only by wave, so for DC = 0. But as we know, the active power at DC is still transferred to the resistor:
##P=\frac{U^{2}}{R_{L}}## (2).
My question is: Which is the relation between (1) and (2)? Is equation (1) simplified somehow?
Thank you in advance!
For DC the equation for Z0 is indeterminate so it won't deliver.
Sorry, there was my mistake, there should be + instead of *, now is correct. But my question is still valid. Which is the relation between (1) and (2)?
At radio frequencies the Zo of the line is involved and at DC it is not, apart from the intial switch-on step function.
Further, if the load impedance has series capacitance, no current flows at DC, apart from switch-on.
Thank you for response! I understand your point of view. But when the impedance consists only resistance, the current flows for DC as well. I still don't see the mathematical relation between (1) and (2). There should be "smooth" switch from (1) to (2).
Ii see what you are getting at but, seriously, could you expect to be working with reactances at 0.001Hz? (Add some more zeros, if you want). There is no sharp switch between AC and DC in practice. The wavelength involved with a very low frequency is so great that any transmission line connecting a source and a load is negligibly short so Transmission Line Equations become meaningless. If you want to reconcile the two regimes then you would need to take the limit of the AC equations as f approaches Zero and that would make the values of some of the parameters impossible to calculate.
As with all of Science, the Maths is the slave of Science and not the other way round. Eventually, the Maths doesn't follow reality.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
