How Does Adjusting Parameter B Affect Servo Motor Friction and System Damping?
In summary, the conversation discusses the mathematical behavior of a servo motor and the factors that affect its performance. The output signal, represented by \$\beta(t)\$, is influenced by two torques - one produced by the electric current and the other by friction. The feedback control system is given by a differential equation with an unknown constant B. By controlling the value of B, the type of poles in the system can be controlled, which in turn affects the damping ratio and the behavior of the motor. The relationship between friction and the system's behavior is complex and influenced by factors such as viscous friction, motor moment of inertia, electromotive force, and torque constant. Overall, a good understanding of the system as a whole is necessary to accurately
Granger
168
2. Homework Equations
[/B]
I'm studying a mathematical behaviour of a servo motor and I need some help to understand it.
The output signal is \$\beta (t)\$, representing the angle rotated by the axis at instant t, in relation to the equilibrium position.
On the servomotor there are two torques:
- the first torque is produced by the electric current \$ i(t) \$ that does through the motor. It is proportional to the electric current being given by \$Ki(t)\$.
- the other torque is given by friction and is given by \$-2 \beta'(t)\$ where \$\beta'(t)\$ is the derivative of \$\beta (t)\$, meaning it represents the angular velocity.
The feedback control system is given by:
[![enter image description here][1]][1]
Where Motor represents the differential equation
\$ 4\beta''(t)=100i(t) - 2 \beta'(t) \$
And \$\alpha(t)\$ is the input angle that give the desired position (angle) for the servomotor.
B is unknown but we will assume A = -1 so that if the input is constant we'll have the output equal to the input (unitary static gain).
The transfer function of the system is:
\$H(s)= \frac{100}{4s^2+(2-100B)s-100A}\$
By this expression we conclude that our system is a second order system with no zeros.
By controlling the value of B we will control where the poles are in our system and by that the type of system we get. More specifically:
- If \$B<-0.38\$ we have two real poles (and an overdamped system)
- If \$B=-0.38\$ we have o double pole (critically damped system)
- If \$-0.38<B<0.02\$ we have two complex conjugated poles (underdamped system).
So until this I don't have questions and everything makes sense to me.
The next affirmation is what leaves me doubtful:
- By controlling the value of B we are controlling the friction of the system.
No more explanation is given to this and I'm kinda worried if my interpretation of this fact is correct or not. Here it goes:
- We have a 2nd order system without zeros. By controlling B we will control the type of poles our system will have. For low values (in module) of B we have an underdamped system. For B=-0.38 the system is critically damped. For B<-0.38 (meaning, large absolute values of B) the system will be overdamped. The system damping is related to the existence of friction in the motor. For low absolute values we will have little friction and so the system will oscillate a lot until it reaches its final value. As we increase B, we will increase friction which will oppose to the natural oscillatory tendency of the system, making it monotonous until it reaches its final values. We have to be careful however because as we increase the friction the system will also take more time to reach the value (it has to "beat" the friction).
Is this interpretation correct? I'm not sure if this is the correct relationship between friction and the type of system I get? I'm also curious if there is any more implication or consequence of this relationship. Can anyone clarify me please?
Thanks!
your image is messed up, we cannot see it.
That being said, I can guess from your transfer function what it is.
Your interpretation is very close, but there are a few things wrong or slightly off.
Granger said:
- If $B<-0.38$ we have two real poles (and an overdamped system)
- If $B=-0.38$ we have o double pole (critically damped system)
- If $-0.38<B<0.02$ we have two complex conjugated poles (underdamped system).
First of all its generally better to talking about your damping ratio (zeta) than your beta values. This will scale the damping relative to your dc offset.
so it becomes
- If zeta>1 we have two real poles (and an overdamped system)
- If zeta=1 we have o double pole (critically damped system)
- If zeta<1 we have two complex conjugated poles (underdamped system).
The above statement will be true for any 2nd order system with no dominant zeros. With beta, as your transfer function changes from controllers, the beta value required for the system to be critically damped with change.
The second thing, what you are calling friction... If in your paragraph you replace 'friction' with 'viscous friction, motor moment of inertia, electromotive force, and torque constant" then it is correct. There are many more items at play than friction. take a look at the below example of how the motor characteristics are defined. The important bits are equation 7 (fill in numbers for the variables, look familiar?) and the physical parameters defining the variables.
http://ctms.engin.umich.edu/CTMS/index.php?example=MotorSpeed&section=SystemModeling
The field is called control SYSTEMS. Everything the motor touches (the system) will effect its performance. Increasing friction would cause a change in the characteristics, as well as changing magnetic fields, changing the motor build, etc. Overall though I'd say you have a decent grasp, you just need to refine a few thoughts you have on the subject.
Likes scottdave
1. What is a servo motor and how does it work?
A servo motor is a type of motor that is commonly used in industrial and robotic applications. It consists of a small DC motor, a gear train, and a control circuit. The control circuit receives signals from a controller and adjusts the motor's speed and position to achieve the desired movement.
2. What are the advantages of using a servo motor?
Servo motors offer high precision and accuracy in controlling movement, making them ideal for tasks that require precise positioning. They also have a high torque-to-weight ratio, meaning they can generate a lot of force in a compact size. Additionally, servo motors have a wide range of speed and can operate at both high and low speeds.
3. How is the analysis of a servo motor performed?
The analysis of a servo motor involves measuring and evaluating various parameters such as torque, speed, efficiency, and power consumption. This is typically done by connecting the motor to a power supply and a load, and then using sensors and data acquisition equipment to collect and analyze the motor's performance under different operating conditions.
4. What are some common applications of servo motors?
Servo motors are commonly used in robotics, automation, and manufacturing industries for tasks such as positioning, pick and place operations, and precision motion control. They are also used in hobby projects, such as remote-controlled cars and planes, and in household appliances like washing machines and air conditioners.
5. How do I select the right servo motor for my application?
The selection of a servo motor depends on various factors such as the required torque, speed, and accuracy, as well as the environmental conditions and budget. It is important to carefully consider these factors and consult with experts to choose a servo motor that meets the specific needs of your application.
