Angle at which a ladder begins to slip
  • Thread starter pech0706
  • Tags
    Angle Slip
In summary, the discrepancy between your answer and the given solution could be due to mistakes in calculations, different approaches or assumptions, or real-world factors affecting the outcome.
pech0706
Consider the ladder in the figure. Assume there is friction between the verticle wall and the ladder, with the coeffecient of static friction=0.30. Find the angle at which the ladder just begins to slip.
[tex]\Sigma[/tex][tex]\tau[/tex]=0=NwLsin[tex]\Theta[/tex]-mg(L/2)sin(90-[tex]\Theta[/tex])
0=+NwLsin[tex]\Theta[/tex]-mg(L/2)cos[tex]\Theta[/tex]
[tex]\Sigma[/tex]Fx[/=0=-Nw+Ffriction
[tex]\Sigma[/tex]Fy=0=NF-mg
Ffriction=[tex]\mu[/tex]sNF=[tex]\mu[/tex]
smg
tan[tex]\Theta[/tex]=1/2[tex]\mu[/tex]s
tan[tex]\Theta[/tex]=1/2(0.30)
tan-1(1.667)=[tex]\Theta[/tex]
59=[tex]\Theta[/tex]
I got 59 but the answer given by the book is 40
. How can I explain this discrepancy?
it is important to carefully analyze and understand the given problem in order to arrive at the correct solution. In this case, the discrepancy between your answer and the one given by the book could be due to a few factors.
Firstly, it is possible that there was a mistake in your calculations or in the given solution. it is important to double check your work and make sure all equations and variables are correctly used. It is also possible that the book's solution may have used a different approach or different values for the coefficient of friction.
Secondly, it is important to consider the assumptions made in the problem. In this case, the problem states that the ladder begins to slip at the given angle, but it does not specify whether the ladder is slipping up or down the wall. This could result in different angles for the ladder to slip, depending on the direction of motion.
Lastly, it is important to consider the real-world factors that may affect the outcome of the problem. In this case, the coefficient of friction may vary depending on the surface of the wall and the ladder, and the weight of the ladder may also affect the calculation. These factors may result in slight discrepancies between theoretical calculations and actual observations.
In conclusion, as a scientist, it is important to carefully analyze the given problem, double check calculations, and consider all relevant factors in order to arrive at the most accurate solution.
Related to Angle at which a ladder begins to slip
What is the angle at which a ladder begins to slip?
The angle at which a ladder begins to slip is commonly known as the "critical angle". This angle can vary depending on the type of surface the ladder is placed on and the weight distribution on the ladder.
What factors affect the angle at which a ladder begins to slip?
The angle at which a ladder begins to slip is affected by various factors including the weight of the person on the ladder, the weight of the ladder itself, the surface the ladder is placed on, and the angle at which the ladder is leaning against the surface.
How can I determine the critical angle for a specific ladder?
To determine the critical angle for a specific ladder, you can use the formula: sinθ = μ, where θ is the critical angle and μ is the coefficient of static friction between the ladder and the surface. You can find the coefficient of static friction for different surfaces in reference tables or by conducting experiments.
Can the critical angle be exceeded without causing the ladder to slip?
Yes, the critical angle can be exceeded without causing the ladder to slip if the coefficient of static friction between the ladder and the surface is high enough. However, it is not recommended to exceed the critical angle as it can be dangerous and increase the risk of the ladder slipping.
What precautions should I take to prevent a ladder from slipping?
To prevent a ladder from slipping, make sure to place it on a level and stable surface, evenly distribute weight on the ladder, and use the correct ladder for the intended task. It is also important to regularly inspect the ladder for any signs of wear and tear and to always follow ladder safety guidelines.
14K
