Approximation of the equation of ellipse
In summary, an ellipse is a flattened circle with a constant sum of distances from two fixed points. Its equation can be approximated using methods such as least squares fitting or linear regression, with the accuracy depending on the number and distribution of data points. With a sufficient number of data points and appropriate methods, a high degree of accuracy can be achieved. Real-world applications of this approximation include modeling planetary orbits, designing curved structures, and analyzing motion in circular or elliptical paths.
Leo Liu
353
156
TL;DR Summary
My physics textbook does the approximation that $$r=\frac{r_0}{1-\frac{A}{r_0}\sin\theta}\approx r_0\left( 1+\frac A r_0\sin\theta\right)$$ when ##A/r_0 \ll 1##. Can someone please explain how it is done?
Mathematics news on Phys.org
##(1-x)^{-1}=\sum_{k=0}^\infty x^k \approx 1+x ## if ##|x|\ll 1.## The terms ##x^2,x^3,## etc. are neglected.
Likes jedishrfu, Keith_McClary, Mayhem and 1 other person
For what it's worth, basically every approximation you see like this in physics comes from the Taylor series of a function. The fact that you see an ##\frac{A}{r_0}\sin(\theta)## suggests that is what's being plugged into the function.
Likes hutchphd
1. What is the equation of an ellipse?
The equation of an ellipse is a mathematical representation of the shape of an ellipse. It can be written in two forms: standard form (x^2/a^2 + y^2/b^2 = 1) or general form (Ax^2 + By^2 + Cx + Dy + E = 0), where a and b are the lengths of the semi-major and semi-minor axes, and A, B, C, D, and E are constants.
2. How do you approximate the equation of an ellipse?
The equation of an ellipse can be approximated by using a method called the method of least squares. This involves finding the best-fit ellipse that minimizes the sum of the squared distances between the data points and the ellipse. This can be done using mathematical algorithms or software programs.
3. What is the importance of approximating the equation of an ellipse?
Approximating the equation of an ellipse is important because it allows us to accurately describe and understand the shape of an ellipse. This can be useful in various fields such as engineering, physics, and astronomy, where ellipses are commonly encountered.
4. What are some real-life applications of approximating the equation of an ellipse?
Approximating the equation of an ellipse has many real-life applications. For example, it can be used in satellite orbit calculations, designing curved structures such as bridges and arches, and modeling the orbits of planets and comets in astronomy.
5. Are there any limitations to approximating the equation of an ellipse?
Yes, there are limitations to approximating the equation of an ellipse. This method assumes that the data points are evenly distributed around the ellipse, which may not always be the case in real-life situations. Additionally, the method may not work well for highly eccentric or elongated ellipses. Other methods, such as the method of moments, may be more suitable for these cases.
  • General Math
  • General Math
