How Do You Calculate the Area of a Shaded Segment of a Circle?
  • MHB
  • Thread starter xyz_1965
  • Tags
    Area
In summary, the area of the shaded segment of a circle with radius 3 cm and central angle 120° is approximately 5.53 cm^2, with the exact expression being (3/4)[4•pi - 3sqrt{3}] cm^2.
xyz_1965
76
Compute the area of the shaded segment of a circle. A segment of a circle is a region bounded by an arc of the circle and its chord. The radius r is given to be 3 cm and the central angle theta is 120°. Give two forms for the answer: an exact expression and a calculator approximation rounded to two decimal places.
Use: area of segment = (area of sector OPQ) - (area of triangle OPQ).
Area of sector OPQ = (1/2)r^2(theta).
Area of triangle OPQ = (ab/2)(sin (theta)).
Solution:
Central angle is theta.
= 120°
= 2•pi/3 rad
Area of the shaded segment
= (Area of the sector) - (Area of the triangle)
= [(1/2) × 3^2 × (2•pi/3) - (1/2) × 3^2 × sin(120°)] cm^2
= [3•pi - (9/2) × sin(180° - 60°)] cm^2
= [3•pi - (9/2) × sin(60°)] cm^2
= [3•pi - (9/2) × (sqrt{3}/2)] cm^2
= [3•pi - (9/4)sqrt{3}] cm^2
= (3/4)[4•pi - 3sqrt{3}] cm^2
= 5.53 cm^2
You say?
Note: All work is done on paper prior to posting.
Mathematics news on Phys.org
Great job on solving the problem and providing both an exact expression and a calculator approximation! Your solution is clear and well-organized, making it easy to follow. Keep up the good work!
What is the "Area of Shaded Segment"?
The "Area of Shaded Segment" refers to the area of a shape that is formed by a segment of a circle and the portion of the circle that is not included in the segment. It is often used in geometry and trigonometry to calculate the area of complex shapes.
How is the "Area of Shaded Segment" calculated?
The formula for calculating the area of a shaded segment varies depending on the specific shape and measurements involved. In general, it involves finding the area of the entire circle and subtracting the area of the segment from it. This can be done using various formulas such as the sector area formula or the segment area formula.
What are some real-world applications of the "Area of Shaded Segment"?
The "Area of Shaded Segment" has many practical applications in fields such as architecture, engineering, and design. For example, it can be used to calculate the area of a window or door opening in a curved wall, or to determine the amount of material needed to create a curved roof or floor.
What are some common mistakes when calculating the "Area of Shaded Segment"?
One common mistake when calculating the "Area of Shaded Segment" is forgetting to convert measurements to the correct units. For example, if the radius of a circle is given in inches, it must be converted to feet before using it in the area formula. Another mistake is using the wrong formula for the specific shape, which can lead to incorrect results.
Are there any online tools or resources for calculating the "Area of Shaded Segment"?
Yes, there are many online calculators and resources available for calculating the "Area of Shaded Segment". These tools can be helpful for double-checking calculations or for quickly finding the area of a shaded segment without having to manually do the calculations. However, it is important to understand the formula and process behind the calculation in order to use these tools effectively.
  • General Math
  • General Math
  • General Math
