Axial symmetry, non-rotating
In summary: Your Name]In summary, axial symmetry and reflection symmetry are two distinct symmetries that are necessary to fully describe a source of gravity. While axial symmetry refers to the source's symmetry along its rotational axis, reflection symmetry refers to its symmetry about a plane of reflection. The second assumption of reflection symmetry adds important constraints to the source and helps to narrow down possible solutions. It also prohibits the source from rotating, which is important for accurate predictions and calculations.
PhyPsy
39
I'm studying Bondi's work on gravitational radiation. He applied axial symmetry and reflection symmetry to a source of gravity. How is it that axial symmetry does not automatically imply reflection symmetry?
The assumption for axial symmetry is [itex]\phi \rightarrow \phi'= \phi +[/itex] constant
The assumption for reflection symmetry is [itex]\phi \rightarrow \phi'= -\phi[/itex]
The first condition implies the second if the constant is [itex]-2\phi[/itex], so I don't see how the second assumption adds anything new to the source.
Also, I read that the second assumption prohibits the solution from rotating, but I don't see why this distinction needs to be made since it is invariant under any rotation.
Hello,
Thank you for your post and for your interest in Bondi's work on gravitational radiation. I can understand your confusion regarding the relationship between axial symmetry and reflection symmetry. While it may seem that the first assumption of axial symmetry already implies the second assumption of reflection symmetry, there are some important distinctions between the two that are crucial for understanding the behavior of sources of gravity.
Firstly, it is important to note that axial symmetry refers to the symmetry of a source of gravity along its rotational axis, while reflection symmetry refers to the symmetry of the source about a plane of reflection. These two symmetries are not the same and cannot be equated.
While axial symmetry does imply that the source has a rotational axis, it does not necessarily mean that the source is symmetric about a plane of reflection. For example, a rotating disc can have axial symmetry, but it is not symmetric about a plane of reflection. This is where the second assumption of reflection symmetry comes into play. It ensures that the source is symmetric about a plane of reflection as well, which is necessary for certain solutions in Bondi's work.
Additionally, the second assumption of reflection symmetry also has implications for the behavior of the source. It prohibits the source from rotating, as you mentioned. This is because under reflection symmetry, the source must remain unchanged, meaning it cannot rotate. This distinction is important because it helps to narrow down the possible solutions for sources of gravity and allows for more accurate predictions and calculations.
I hope this helps to clarify the relationship between axial symmetry and reflection symmetry in the context of Bondi's work on gravitational radiation. If you have any further questions or concerns, please do not hesitate to ask. Thank you again for your post and for your interest in this fascinating topic.
Related to Axial symmetry, non-rotating
What is axial symmetry?
Axial symmetry is a type of symmetry in which an object or system has a central axis that divides it into two mirror images that are identical.
What is non-rotating symmetry?
Non-rotating symmetry, also known as translational symmetry, is a type of symmetry in which an object or system remains unchanged when it is translated or shifted in space.
What are some examples of objects with axial symmetry?
Some examples of objects with axial symmetry include a cylinder, a sphere, and a human body when it is standing upright.
Can an object have both axial and non-rotating symmetry?
Yes, an object can have both axial and non-rotating symmetry. For example, a cube has both types of symmetry because it can be rotated around its central axis without changing its appearance and it also remains unchanged when it is translated in space.
What are the practical applications of studying axial symmetry and non-rotating symmetry?
Studying axial symmetry and non-rotating symmetry is important in various fields such as physics, chemistry, and engineering. It helps us understand the properties and behavior of objects and systems, which can be applied in designing structures, predicting the movement of particles, and analyzing chemical reactions, among others.
