Is a New Principle Necessary to Resolve Quantum Gravity and Unify Interactions?
In summary: QFT, it has always been pushing the envelope in new ways. So I don't think there is any reason to believe that it will stop now.
  • #36
arivero said:
Other favorite idea of me is "Dual quark-gluon model of hadrons", by J.H. Schwarz, Phys.Lett.B37:315-319,1971. There he proposes to consider supersymmetry between quarks and the QCD string, instead of a whole set of new particles.
Careful said:
I don't know about this one, but how do the degrees of freedom match? You have 12 quarks (anti-quarks included), normally you have 8 gluons, so you have 4 degrees of freedom too much. What kind of new physics do these guys give?
It seems that the idea was abandoned next year, in favour of fundamental supersymmetry. I asked the author but he does not remember the specific arguments against; probably it was something in the line you mention. But I think this idea was the right one. The d.o.f match if you consider "terminated gluons", ie the string with two quarks attached at the end, and the same symmetrization strategy that the pion, only that in this case each pair of quarks + gluon can appear in the three colours of the SU(3) triplet, instead of the singlet of the pion.
Regretly, in 1971 only 3 quarks were known (and a 4th conjectured) and all of them were light. For this combination, the d.o.f do not match: you get (modulo colour) two anti-down "boson d.o.f." from ud and us, and three anti-up from ds, dd, ss. Plus the same with the antiparticles. So with three quarks you can only build fully one down and one up, and some degrees must be discarded even having the same charges that the ones you are pairing to. But I like to think that, with foresight, superstring theory actually had the opportunity to predict five light quarks and one massive.
  • #37
Careful said:
:smile::smile::smile: You were joking right ? :wink:
No need to go hysterical on me. Just tell me your objection in as clear manner as you can, save the sarcasm.
  • #38
Let me see if I understand what you say: (a) the gluons have to be (electric) charge neutral
(b) they have to be Lorentz vectors, so particles couple to antiparticles (c) They have to be permutation invariant if you permute over the generations (d) the strings are not oriented (so only the combination counts).
Ok, so you can subdivide the quarks in two families : (u,c,t) and (d,s,b) each of them can be considered separately.
Right, let us look at the permutation group S_3 now, we have to look for the subclasses L of permutations such that BLB = L for all B in S_3. This gives rise to two combinations
uu* + cc* + tt* , uc* + ct* + tu* + cu* + tc* + ut* for the symmetric ones,
uc* - cu* + ct* - t*c + tu* - ut* for the totally antisymmetric one and then there still is one mixed Young tableau, which gives 4 in total. 4 times 2 is eight indeed. Was this the idea? But then, what is the dynamics of the string?
Question : will you not get in trouble here with Lorentz invariance (unless you have a different quantization scheme than Fock space).
I will have to think about this, no time now.
Careful
  • #39
If you were not joking, then I am not even going to try. The gaps in what you tell are too wide to be filled in one full evening and I don't have the necessary time, sorry.
Careful
  • #40
"careful" claims that he would loose his time on you. My advice : I stopped loosing my time on him.
  • #41
No, the idea is a bit [STRIKE]more complicated[/STRIKE] simpler because the gluon is electrically neutral, but the quarks are not. So we must associate terminated strings [up----down] to built the "antidown scalarfermions", and terminations [down----down] to the "antiup sfermions". The symmetrization acts in SU(3) colour to produce the colour triplet from 3x3=6+3 as usual, and then in flavour space with five light quarks we take the 15 of 5x5=15+10. This actually contains as a subgroup the 6 of the combination (d,s,b) as we could expect, and it contains the up---down pairs too. You were building the octet of 3x3, which is relevant for neutral leptons only, not for quarks.
But I am stating just the symmetrization of the final result. More verbosely, let me to show again in, with this setup, how "superstring" (dual quark/gluon) theory "predicts" the number of generations. Let n "down" and m "up" quarks to produce p "down" and q up quarks, and let's ask this production to be exact, not having "half spinors" or, worse, single bosons. Then we have two Diophantine equations.
For down quarks, 2 p = n*m while
For up quarks, 2 q = n*(n+1)/2
In 1971, as said above, n=2 (down and strange) and m=1 (the up), so p=1 and q=1.5, and the attempt is doomed to fail: because p<n and because q is not integer.
Note that the second equation tells us that either n or n+1 must be a multiple of 4. If n+1 is multiple of 4, the first equation only works has solutions for even m.
So, here you can see the table of first p,q pairs for each n,m:
Code:
p,q    3     4      7       8   ...
1     --   2,5     --     4,18   ...
2    3,3   4,5    7,14    8,18   ...
3     --   6,5     --    12,18   ...
4    6,3   8,5   14,14   16,18   ...
5     --  10,5     --    20,18   ...
6    9,3  12,5   21,14   24,18   33,33    ...
And two observations follow:
- the case m=1 actually implies p<n, so that the number of "down" type quarks we can produce in this case is less than the input we started from.
- the simplest case is p=q=3 from n=3,m=2. This is the standard model quark content.
  • #42
The feelings are entirely mutual o:) At last a sociological issue we agree upon. But if you feel like having the time to explain to qsa why his claim is ''not so well considered'' to use a euphemism, be my guest. :biggrin:
Careful
  • #43
Careful said:
This is already a more extensive laundry list. But the question now is, in which logical order are you going to place these issues? Is even one of them a pressing issue or can they all be derived from something which is beyond imagination (in either 99,999%) of most people currently?
Obviously I am biased, since it has to do with my own speciality, but I would say dark matter is the most obvious 'pressing' issue, since it is by now pretty airtight experimentally and in clear conflict with the standard story. Further, you can run 'what else can it be' arguments at length and pretty much arive at the conclusion that it must be either something highly exotic, or basically just another particle.
If the latter, on dimensional grounds, in order to have evaded detection such an object either has to be very light or basically in the nearby energy range that the LHC is going to probe.
In any event, it is almost certainly guarenteed to be an extension of the standard model.
  • #44
I think I see the problem, but I think that the issue is solved by the gluon itself, which provides some indexes to couple to the quarks where it "terminates", so the whole object should be a Lorentz scalar, shouldn't it? Or should actually this way drive us to the topic of the anomalies of the quantum string and the infamous D=10 prediction?
  • #45
Everything I wrote down is electrically neutral.
None of those are electrically neutral so they cannot gluons, You said the point was to construct gluons from quarks attached to a string and now you are constructing something else.
I didn't think about these issues, but which ones are the five light quarks? I know the top quark is 40 times heavier than the bottom quark, but 40 is still a small number. And flavour is supposed to be just a quantum number, so I don't know what flavour space is supposed to mean.
I can build whatever I want to, if you claim to have an alternative theory for the gluons then you will have to explain why the very legitimate representation I constructed is not allowed. Building a theory does not only consist into playing with representations.
So, I constructed 8 bosonic particles from quarks, nothing you wrote suggests you do the same. You seem to introduce moreover some new continuous group SU(5) (?) without any motivation where it comes from (SU(3) has no 5 dimensional representation).
Careful
  • #46
I thought gauge particles were supposed to be Lorentz vectors. Normally you need the gamma matrices for that if you write them as composite particles.
  • #47
I think a relativistic MOND theory is by far the most reasonable explanation for dark matter. It doesn't require any exotic new physics, just a non-local deformation of gravity.
Careful
  • #48
Also this I do not get, if you would have a mechanism to build gluons from quarks then of course you just cannot assume the quarks carry an SU(3) index to start with. That's basically what you would like to derive no?
  • #49
Ah, I see now the confusion! Big one, my fault. My point was the reversal: to consider gluons as equal to the the QCD string, and attach quarks to them in order to build the susy scalars (and thus match to the d.o.f of quarks).
Indeed your construction is the right one to build 8 gluons from 3 quarks, and I keep thinking about if it has a meaning too, beyond the usual of representation theory. In my construction, symmetrization wipes the d.o.f. of gluons from 8 to 3, in your construction the pairs allow to go from 3 to 8. This is the expected working of SU(3), juggling between adjoint and fundamental representations, of course.
From the mechanism I sketched, a "light" quark is a quark that you can attach at the end of the string. Somehow, Nature gets to incorporate this "ban to attachment" in the top quark, it decays faster than the theoretical half-life of a possible 'toponium' meson. From naturalness principle, these five quarks should have a hidden symmetry protecting them when, at electroweak symmetry breaking, the top gets its mass. We don't know what this symmetry is, as far as I have read.
But it is! When your construction is applied to SU(3) colour, it produces the colour octet. When it is applied to (u,d,s), it produces the famous flavour octet of GellMann. And when applied to families, as you did, it seems to produce again the same content that gluons, and then one is left wondering if there is a relationship between SU(3) family and SU(3) colour. I think this path was pursued in the literature in the late seventies.
What I build was different: I built 18 (=3x(3x2)) particles of charge +2/3, 18 of charge -2/3, 18 of charge -1/3 and 18 of charge +1/3 by putting quarks at the extremes of the QCD string. Again, sorry the confusion.
Yes, I did it to illustrate the symmetrization, I called it flavour space instead of naming explicitly as SU(5). I though that it followed from my remark on five light quarks, in the typical way that flavour symmetry is always described. The only difference is that usually the SU(3) flavour inside of SU(5) flavour is built only from mass, they take the u,d,s out of the u,d,s,c,b set. I consider all the five quarks equally massless, and I try to commute with electrical charge, so I take d,s,b in my illustration.
In fact, I feel that to use SU(5) in this way is correct because besides finding six +2/3 and six -1/3 in the 15 of 5x5, you can notice that the 24 in 5x5=24+1 happens to contain 6 states of charge +1, 6 of charge -1, and 12 neutrals. That is three generations of sleptons.
  • #50
We misunderstood ourselves completely :confused: My point (and our common point) was that the original try was to claim that the the gluon was the superpartner of the quark, and it fails obviously. The gluon is a boson, so I noticed that by adding to the gluon a pair of quarks the statistics does not change, it is very like the Chan-Paton idea, and the resultant system has the multiplicities of three families of squarks. The mechanism you understood instead also allows to reproduce the gluons, via the mysterious colour/flavour diagonal of the late seventies, but I feel that it hides the supersymmetric aspect of the original theory.
  • #51
I have been in the management for 20 years, and I have seen all kinds. Hired and fired many, but only on the merits of their work, never their personality, since mine is not perfect either. I am here on PF to learn and I have learned much more than I hoped for. I will listen to ALL, and put up with some nuisances, that is just normal in business and life.
  • #52
Since you have been in management and I know how difficult job managers have (it requires a kind of intelligence I don't possess), let me explain a bit why unifying gravitation and electromagnetism is far from sufficient. First of all, you would not have a quantum theory to start with, second since 1940 people discovered the weak and strong interactions; Einstein was completely unaware of that. I don't know what your level of technical expertise is, but there are a few good introductory papers which explain in a pretty basic way what kind of difficulties you can expect trying to wed GR and QM. Let me give a few in increasing order of technical difficulty:
http://www.phy.syr.edu/~sorkin/some.papers/82.forks.pdf
http://arxiv.org/PS_cache/gr-qc/pdf/9210/9210011v1.pdf
http://arxiv.org/PS_cache/gr-qc/pdf/0602/0602013v2.pdf
This should do, especially the second one is a deeply written survey paper.
Careful
  • #53
I will respond to you tomorrow, have work to do now. :smile:
Careful
  • #54
Arivero, I am confused by what your trying to accomplish. According to papers I could find, quark-diquark supersymmetry help in simplifying scattering calculations because it supposes that baryons on strong couple can be well approximated by a quark bound to a super symmetric parter. While the possible verification of this kind of approximation is extremely important to the study of nuclear forces, I don`t see how could that be relevant to fundamental issues that could have the label "beyond the standard model".
  • #55
Careful
Thank for the reply, I had a feeling that it was just some misunderstanding. I don't know about the other people on pf, but I think we see the forum as a place to learn. probably more regulars here are not really hard core physicists, but we are here to know ( and sometime fantasize about discovering) what reality is all about. So for lot of us it is not a matter of "my idea is better than yours", but I think more like "my idea is worth thinking about-could you agree -". People like tom have been instrumental in giving an overall picture for the many uninitiated, tom himself is an engineer just like me. I had to practice management and I hated it, people can be difficult, you know; I had rather be a geek.
Anyway, I think my bad wording has caused mostly the misunderstanding(twice), not to mention you jumping the gun in the heated battle. I know the unification( classical) EM with gravity has been a loosing battle (Einstein -non-symmetric) , although to this day some people are still trying. but I meant more like QED side of EM, I just used EM as generic. Of course, I don't usually shoot off my mouth without having something important to say, not my nature. Yes, I am very familiar with the problems of unifying QM and GR. My level of technical expertise is not that great I admit, but I have learned to be a good problem solver with minimum information that time and circumstances allow. I have to go now( very late at night), but you will get what I mean in the next few days in black and white.
  • #56
Somehow I lost track.
Did we manage to identify some new principles or indications what they could be?
I guess the last papers Careful mentioned should provide some guideline; especially Sorkin is far from mainstream and could perhaps have some reasonable ideas - besides his causal sets.
My problem is that most answers seem to be in the nagative; there are indications how things will NOT work (or only to a certain approximation). But I am afraid that we here cannot be smarter than excellent thinkers out there ...
  • #57
The real point in the literature are not the quark-diquark models, but the so called "dual pion quark" and "dual gluon quark" models, and similarly named schemes, that appeared during 1971-1973 after the paper of Ramond on the spin 1/2 version of the "dual model". Eventually these models dissappeared, being substituted either by fully fundamental strings (going to the actual impasse) or by simple, non fundamental at all, calculational tools as you say. BTW, these attemps actually started with work of Utiyama, predating the string discovery of susy.
What I am trying to accomplish? Well, I think was trying to address two small problems, one one side the fact that some mass relationships seem to be related to composite models, while the quarks and leptons have no structure, and in other side the fact that there are coincidences between mass scales of very different origin, the "QCD" masses and the "yukawa-electroweak" masses. There is no fundamental reason for QCD to produce masses in the same "mountain ranges" that the electroweak+yukawa. This is a kind of "fine tunning" not explained in GUT models.
What I show? That the first hunch, when supplemented with quark flavours, was better that the fully fundamental way. And that actually it predicts the generation structure of the standard model, not only the number of generations, but also the number of "massless" quarks.
Of course, but this is unimportant, my discovery process was in the reverse way, upstream. First I wondered about the mass of the muon... Why is it so near of the pion mass? If it were for SUSY, we should have the same number of fermion that bosons, hmm, let's count... three spin 1/2 negative leptons... and six different ways of making negative mesons! Shock. Then I asked, but what about quarks, and again, for +2/3 and for -1/3 the degrees of freedom match. Shocking thing. Then for neutrinos you get naively 1 degree of freedom more, telling that you mast to do SU(5) instead of U(5). Then I checked uniqueness, as described above, and yep the 3 generations is the simplest model, and it becomes unique in fact if you incorporate the requisity of building neutrinos from neutrals in SU(n+m). Only at this level I checked the literature must deeply and I found that these kind of models were the first ones in the mind of the string people, but at that time they only know 3 quarks, so even if they had got to predict the generations, it had been discarded as far-fetched.
Careful
Thanks, I appreciate your interaction :-)
  • #58
tom.stoer said:
Did we manage to identify some new principes or indications what they could be?
I think yes. We are doing heavy use of the (′t Hooft) naturalness principle, that anything which is not massive is massless at tree level.
  • #59
The causaly set ideas, at least partially clearly tangent to the direction I mentioned with inference, ordering and counting. It was some time since I look into that, can someone point towards say a current review of the state of this research program?
What I particularly found missing the last time, is the evolution (or expected dynamics) of the causal sets themselves, and how to connect matter to the causal set program. It's not hard to associate to possible ideas, but what are the concrete proposal so far from this program to these questions?
I fully share the idea that one way or the other "ordering" and "counting" are two two deep key points, that I doubt can under overstated at this point.
Anyone knows of a current revivew of the causet program?
/Fredrik
  • #60
Fra, the point is that while causal set ideas seem relevant to the question of foundations of quantum mechanics, it is hard to see how they can produce the SM, not to say something BSM (and including the SM). If they can, it will be probably connected to operator theory, C* algebra approach to geometry and, at the end, Connes' theory, but I'd expect 50-75 years time of development. And it surprises me its use for gravity "a la Sorkin", but ok, they could be suitable there.
Now, when I was younger I thought that the number of generations could have a direct connection to quantization procedures. While I do not pursue more this idea, it could be a way to connect foundational arguments with actual particles.
In the last century, I read an enjoyed this one: http://jmp.aip.org/resource/1/jmapaq/v5/i4/p490_s1?isAuthorized=no
  • #61
It seems certain that the Standard Model is pretty much correct, the linear group structures do exist in nature. But what is renormalisation doing there, seemingly muddying this beautiful mathematical structure? I think one new physical principle needed is to take the idea of non-local evolution seriously, and just admit that the local structure of QFT is only an approximation. Renormalisation is probably discarding the (small (net)) contributions of the rest of the universe to each and every subsystem within it.
And also I think we need to be less greedy, it may be just not possible to say anything about reality below Planck scale. And maybe gravity is just statistical (entropic)?
And then we have the elephant in the room, human consciousness and free-will. But I think the "measurement problem" is a red-herring, since the universe evolved quite happily before we did, the real open problem is "free-will" and conscious awareness.
  • #62
Thanks for the link Arivero. Just from the title I suspect it's related to Knuths "derivation" of lorentz symmetry from consistency constraints on any valuation of partial ordered sets.
I definitely think that the basic questions here (not just causal sets) or counting and origin an emergence of ordering can in principle connect to SM, and the action of matter. Ordering and counting are closely related in some views, you can consider ordering defined by counting evidence. So the counters define NEW orders. There is more of course... this is what I mean that that I do not see problems in imagine how it may be done, but I agree that 50-70 years might be realistic. But I don't think that should discourage us. It doesn't discourage me at least. Also, the more people looking at tht is really the problems, the more can ew reduce that time, right?
But after refreshing my memory in the other thread, I think I agree that at least as far as we constrain ourselfs to the so called causal set programme, it seems to have hard to connect to SM like you say. This is in part why I do not like it. Some of the founding ideas are good, but they don't go far enough.
/Fredrik
  • #63
Forum =
1. a. The public square or marketplace of an ancient Roman city that was the assembly place for judicial activity and public business.
b. A public meeting place for open discussion.
c. A medium for open discussion or voicing of ideas, such as a newspaper, a radio or television program, or a website.
2. A public meeting or presentation involving a discussion usually among experts and often including audience participation.
3. A court of law; a tribunal.
Even then, you will have to do something far more generic than just that.
Careful
  • #64
I said many times that those things do not happen over public forum.
Sorkin was mainstream for the first part of his life; he investigated important questions in canonical quantum gravity amongst many other things. Let me phrase it this way, IF nature is discrete, THEN Sorkin's scheme is the only possible one (which has a nonzero chance) I am aware of. But he also works on the foundations of quantum mechanics, extensions of logic and so on.
Well negative answers are the beginning to positive ones. What did you expect? That life is easy? And that you will suddenly deeply realize what the real problems are?
There are people out there working whole their lives at those things and still they come up with partial answers. You would be surprised what people have thought about and never reached the ''media''.
Careful
  • #65
Your opinion
No
I know
I know
  • #66
Feynman "lockbox combination" example was about illustrating it. People works during half a life trying to open a lockbox, and casual by-passers tell them "have you tried, say, 34-54-27?". Surely yes, they have tried.
(hmm, can anybody provide the exact quotation for Feynman paragraph? I remember it only vaguely)
  • #67
Ok, you do suzy in the ''reverse'', I added 1/2 spin, you substract 1/2 spin. Just a tiny question: won't these scalar particles cause lot's of trouble?
Long time ago I played with these representations, so I had to refresh my memory by going straight to the Young diagrams.
Therefore, also my confusion when you suddenly pulled out a 5 of your hat :wink:
I did not delve into this literature (one cannot do everything in life) so I am trying to learn here.
Ok, now I see what you try, let me see your original post again and redo your arguments for myself.
Careful
  • #68
Careful said:
... IF nature is discrete, THEN Sorkin's scheme is the only possible one (which has a nonzero chance) I am aware of.
Why? Are there positive reasons for Sorkin's approach, or only negative ones against everything else?
And what do you mean by "discrete"? You can put in discreteness by hand, or discreteness can be a result; spin is discrete even if it follows from a continuous symmetry. If AS or some other ansatz identifies some kind of "minimum physical length" then nature "is" essentially discrete. Contínuous symmetry would then be some kind of "unphysical symmetry", like gauge symmetry.
  • #69
tom.stoer said:
Your opinion
Just common sense.
tom.stoer said:
I know
No, I don't think you know... I thought that I knew a lot about non mainstream approaches, but I get surprised still every day! Always, some obscure Rumanian, Italian or Chinese guy pops up having published nice (similar/partial) results in some unknown editorial simply because the main publishers would regard this as ''dark'' science. I presume that in your case, you are just at the tip of the iceberg.
Careful
  • #70
The main argument is negative, Sorkin's approach is the only one which respects Poincare symmetry (which is a very nontrivial statement). There are some positive arguments too, but they are not too compelling in my view.
Obviously, I mean fundamental discreteness, everybody does so.
Haha, sure, would you mind construct the relevant non-local operators for me please ? :-p
  • Beyond the Standard Models
