Boat crossing/Glide Ratio/Hydraulic design
  • Thread starter zeshkani1985
  • Tags
    Boat Design
In summary, The first question is about calculating the distance of a runway from a building based on the glide ratio of an aircraft and its clearance above the building. The second question involves finding the position and direction of a boat crossing a river with a current using the law of sines. The last question asks for the minimum height of a reserve tank in a hydraulic system, given the diameter of the tank and the length of the lines connecting to it.
zeshkani1985
Ok I had these 3 questions: I believe I have ansered the first 2 but I' am just stuck on the third.
1. an aircraft has a glide ratio of 12 to1 m, a building that is 45m high lies directly in the glide path, the plane clears the building by 12m, how far is the run way from the building?
ANS: I just took the 12mx45m= to give me 540m i' am pretty sure this is right?
2.to cross a river that is 1km wide, with a current of 6km/hr, a boat that is perpendicular to the far bank, the boat speed is 10km/hr. at what position will the boat actually contact the far bank? what direction should the boat have to cross directly across?
ANS: here i made a right triangle and just used the 6^2 +10^2 = x^2, so he will actually contact the far bank at 11.6km away. 2part: since having figured out his actual contact point i figured the angle and by using the law of sines that it was 31.3 degrees
I think the first part is right, i' am not sure about the 2nd
3. design a hydraulic holding system for a hay-baling system, the system has four cylinders with a 120mm diameter pistons with a stroke of 0.320m, the lines connecting the system are 1cm id(inside diameter). there are 15.5m of lines in the system. for proper design, the reserve tank should hold a minimum of 50% more then the amount of hydraulic fluid in the system, if the diameter of the reserve tank is 30.48cm what is the shortest height it should be?
This question I' am completely stuck on, I have no idea were to start, any pointers would be great
Not quite. You missed the bit about the plane clearing the building by 12 ft.
so it would be 540m-12m = 528m ?
You mean, the faster he goes towards the other bank, the longer it would take him? Like, if his speed is 100 km/hr he would land 100^2 + 6^2 = x^2 below where he started? You know that can't be right.
Hint: he takes the same amount of time to reach the other shore no matter how fast the river is moving ... so how much time is that, and then how far below his starting point does the flowing river take him?
No. Doesn't it make sense that the higher he clears the building, the farther he has to fly before hitting the runway? Draw a picture ...
okay i think i got it, so the plane is acutally 12m above the building, if this is the case, then there is an extra 12m
okay since the boat velocity is at 10km/h, and the river at 6km/h
6km/h __
10km/h|/ since there are 2 velocities, 102+62=11.6km/h that's the diagonal speed
so with this i can just divide the distance of 1km/10km/h =t to get time and multiply velocity by time to get the distance 11.6km/h x 0.1h= 1.16km is this right ?? for the first part
for the second part in question 2
can i just take the inverse of cos of the distance of the river/by the boat speed
cos=1/10=85 degrees
6km/h __
You have the total distance traveled right but the question really asks how far below the launching point does he arrive on the other side.
rude man said:
You have the total distance traveled right but the question really asks how far below the launching point does he arrive on the other side.[/QUOT
1st thanks for the help
i think i got it can i just use the triangle theorm can't spell it A2+B2=C2
so A=√of 1.162-12
= 0.58km
cos=1/10=85 degrees
No.
He'll point his boat at an angle θ from the straight-across direction. So write an equation giving the along-the-bank distance he travels in time T. You can set up a coordinate system fixed to the ground, with the river flowing in the -y direction and the distance along the river bottom = x. x = 1km and y = 0 would be the point directly across from his launch point, which would be x = y = 0.
so A=√of 1.162-12
= 0.58km
Close enough to 0.6km I guess. You know t = 0.1 hr so 0.1 x 6 km/hr = 0.6 km.
rude man said:
No.
i just looked at the problem again and i set it up differently and i took the inverse tan
and I got a 5.7 degrees, but since this is just the angle, would you add the 180+5.7 to get 185.7 ?
I don't know where you got the inverse tangent.
Set up as I suggested and write the distance equation for the y coordinate. You don't know T, the time of crossing, but you don't need to to answer part 2.
(The angle is between 0 and 90 degrees, that should be obvious. And it's bigger than 5.7 deg.)
okay i did set it up how you said so here is my question, i' am just kind a really confused over it
i will be using sin, since i know the opposite and hypotenuse since the opposite it 6km/h for the hypotenuse do i use the 10km/h or the 11.6km/hr from the previous answer if i just use the 6/10 i get 36 degrees if i use the 6/11.6 i get 31 degrees
i think i got it the angle should be 31 degrees i used this and back substituted it and found out that is had to b e 31 degrees.
What equation did you use to arrive at 31 deg? If you did as I suggested you first got an equation for the total y component of velocity of the boat wrt the ground (riverbottom). This equation includes the y component of the boat's intrinsic speed (speed on a quiet surface) plus the y speed of the river. You then multiplied this resultant y speed by time T to cross the river to get the final y position. You then set that final position to y = 0.
The y component of intrinsic boat speed is going to include the angle he points the boat to.
(My answer is close to one of your answers but it should be closer than it is, so please show your work.)
okay here i did it again
since i know that his displacement was .60km due south and the river is 1km wide
so to balance it out he had to go .60km due north to cross directly and i took the inverse tan of .60km/1km to get 30.96 which is about 31 degrees
i think i might just give up
1. What is a boat crossing?
A boat crossing is the process of moving a boat from one side of a body of water to the other. This can be done by a variety of methods, such as rowing, sailing, or using a motorized boat.
2. What is glide ratio?
Glide ratio is a measurement used to determine the efficiency of a boat's movement through water. It is calculated by dividing the distance traveled by the boat by the distance it descends during that time. A higher glide ratio indicates a more efficient use of energy and a smoother movement through the water.
3. Why is hydraulic design important for boats?
Hydraulic design is important for boats because it affects the performance, stability, and safety of the vessel. The design of the hull, keel, and other components can impact the boat's speed, maneuverability, and resistance to waves and strong currents.
4. How is the glide ratio of a boat affected by its design?
The design of a boat can greatly impact its glide ratio. Factors such as the shape and size of the hull, weight distribution, and the presence of features like keels or foils can all affect the boat's ability to move smoothly through the water and maintain a high glide ratio.
5. Can the glide ratio of a boat be improved?
Yes, the glide ratio of a boat can be improved through various means, such as optimizing the design of the hull and other components, reducing weight, and using advanced materials. Proper maintenance and upkeep of the boat can also help to maintain a high glide ratio over time.
  • Mechanical Engineering
9K
