Calculate Volume of Tetrahedron with Given Vertices | Step-by-Step Solution
madachi
Find the volume of the tetrahedron with vertices at (0,0,0),(1,0,0),(0,1,0),(0,0,1)
I worked out the triple integral and found out that the volume is \frac{1}{6}? Is this correct? I know there is probably a much quicker way working the volume by just using the volume formula for tetrahedron. However, I am not sure which value to substitute to the formula, so could you just tell me whether this answer is right or not?
Thanks!
The vertices you give do not make a tetrahedron. Try to draw the points in three dimensions. You'll see the volume is just half that of a cube with length 1. So the volume you're seeking should be 1/2.
For a tetrahedron, like a cone, the area is (1/3)*(area of the base)*height. So (1/3)*(1/2)*1=1/6, yes.
Mr. Miyagi is wrong. That is in fact a tetrahedron, it is 1/6 of a cube, not 1/2, and its volume is, indeed, 1/6.
More generally, the volume of the tetrahedron is with vertices at (0, 0, 0), (a, 0, 0), (0, b, 0), and (0, 0, c) is (abc)/6.
Ugh, sorry about that... Is it too late to claim temporary insanity? :rolleyes:
Thanks for correcting it so quickly.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
