Calculating g force for flywheel
  • Thread starter Thread starter wakadarc
    Flywheel Force
To determine the RPM at which a flywheel with an offset shaft travels faster than gravity, the calculation involves using the formula for gravitational acceleration and angular velocity. The flywheel's diameter is 0.1524m, leading to an angular velocity of approximately 21.82 rad/s, which translates to 208 RPM. However, this approach is deemed incorrect as a more suitable formula for centrifugal forces should be applied. A revised calculation indicates that to achieve an acceleration greater than 1g, the RPM should be around 600+, with a free-fall time of 0.176 seconds resulting in 2.47g acceleration. Accurate conversions and understanding of the vertical component are crucial for precise calculations.
wakadarc
I need to determine the RPM just that the flywheel (that has an offset shaft) will travel faster than gravity (g force). Meaning my offset shaft will be falling faster than a falling object per se.
So flywheel has a diameter of 0.1524m.
h=1/2g*t^2
t=0.144s (assuming we did 1.5x(9.8m/s) with h=0.1524m)
angular velocity = 3.14/t = 3.14/0.144s = 21.82 rad/s
Therefore the RPM is 208 RPM (1 rad/s = 9.55 RPM)
Is this the right approach? Thank you.
wakadarc said:
h=1/2g*t^2
Where does that formula come from and what does it represent?
Why pi/t?
It is not the right approach.
There is a simple formula for centrifugal/centripetal forces, you can directly use it.
I am simulating a ball dropping at the top of a circle and the time it takes to reach the bottom, hence using pi. The ball is under the g force.But I've seen this
http://www.calctool.org/CALC/phys/Newtonian/centrifugal
This calculates the centrifugal force but i need the vertical component to be greater than g (downward gravity force)
Ah, then I misunderstood your first post. I thought you were interested in the instantaneous acceleration.
Okay, then your approach is right.
So the offset shaft will fall (or in reality, rotate about the center) at 1.5gs if I have 208 RPM?
The centrifugal approach from the link I posted has it higher, 600+ RPM
I checked the numbers. With your diameter, I get 0.176 seconds of free-fall time. That corresponds to 17.823/s or 170.2 rpm.
Using those numbers, the tool gives 2.47 g acceleration. That looks reasonable. Don't forget to convert diameter to radius.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
