Calculating Initial Velocity
In summary, a knight's squire drops sandbags from a 12.0 meter tower. At exactly the same time the sandbag is dropped, the knight shoots an arrow up at the sandbag from the base of the tower. If the arrow strikes the sandbag at exactly 1.1 seconds, calculate a) how far from the ground the arrow strikes the sandbag, and b) the arrow's initial velocity.
killaI9BI
51
For archery practice, a knight's squire drops sandbags from a 12.0 meter tower. At exactly the same time the sandbag is dropped, the knight shoots an arrow up at the sandbag from the base of the tower. If the arrow strikes the sandbag at exactly 1.1 seconds, calculate a) how far from the ground the arrow strikes the sandbag, and b) the arrow's initial velocity
d = ½(vi + vf)t
vi = (d/t) – ((a x t)/2)
a) d = ½(-9.8)1.1
d = -5.39
12 - 5.39 = 6.61
The arrow strikes the sandbag at 6.6 m from the ground
b) vi = (6.61/1.1) – (((-9.8) x 1.1)/2)
vi = 6 – (-5.39)
vi = 0.41 m/s
Does this look right?
d = ½(vi + vf)t
a) d = ½(-9.8)1.1
d = -5.39
12 - 5.39 = 6.61
vi = 6 – (-5.39)
vi = 0.41 m/s
You might want to check this calculation:
a) d = ½(-9.8)1.1
d = -5.39
Remember, the sandbags are free-falling after being dropped, so their velocity is accelerating as they fall.
Don't forget to indicate the correct units for your answers.
d = vi X t + 1/2a X t2
that would be a better formula because (-9.8) is the rate of acceleration, not velocity. Thank you for that!
d = 1.1 + 1/2(-9.8) X 1.12
d = (-4.829)
d = (-4.8) m
12 – 4.829 = 7.171m
a)7.2 m
b)vi = (d/t) – ((a x t)/2)
vi = (7.17/1.1) – (((-9.8) x 1.1)/2)
vi = 11.9 m/s
Does that look right now?
d = (-4.829)
d = (-4.8) m
12 – 4.829 = 7.171m
a)7.2 m
vi = 11.9 m/s
You're veering out of control now. You fixed one problem and have introduced another into your calculations:
This is the correct formula. So far, so good.
d = (-4.829)
d = (-4.8) m
12 – 4.829 = 7.171m
What is vi for the sandbags when they are dropped from the tower?
I thought that vi would be zero for the sandbags.
should it be (-9.8) m/s?
It would be zero.
This seems to imply that the initial velocity is 1 m/s (zero times 1.1 is zero, not 1.1)
face palm!
d = ½(-9.8) X 1.12
d = (-5.929) m
12 – 5.929 = 6.071 m
a) 6.1 m
b) vi = (d/t) – ((a x t)/2)
vi = (6.071/1.1) – (((-9.8) x 1.1)/2)
vi = 5.519 – (-5.39)
vi = 10.9 m/s
Thank you very much!
just to be certain, can you confirm that what I've done looks right?
thanks again!
thanks again!
Yes you're correct, and you're welcome.
:biggrin:yay!
1. What is initial velocity?
Initial velocity, also known as initial speed, is the velocity of an object at the beginning of its motion. It is the speed and direction at which an object is moving when it first starts moving.
2. How do you calculate initial velocity?
Initial velocity can be calculated by dividing the displacement of an object by the time it takes to travel that distance. The formula is v0 = d/t, where v0 is the initial velocity, d is the displacement, and t is the time taken.
3. What is the difference between initial velocity and final velocity?
Initial velocity is the velocity of an object at the beginning of its motion, while final velocity is the velocity of the object at the end of its motion. Initial velocity is often denoted as v0 and final velocity as vf.
4. How does initial velocity affect an object's motion?
Initial velocity affects an object's motion by determining its speed and direction at the beginning of its motion. It is a crucial factor in calculating an object's position, velocity, and acceleration at any given time during its motion.
5. Can initial velocity be negative?
Yes, initial velocity can be negative. A negative initial velocity indicates that the object is moving in the opposite direction of the positive direction. It is important to consider the direction of initial velocity when analyzing an object's motion.
